Steering Stabilizer what you got?? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 28 Old 11-13-2010, 06:00 PM Thread Starter
I am getting ready to change mine as it is shot. My question for everyone is which one are you running and how do you like it pro's / con's. Thanks in advance. I am particularly interested in those running the bilstien.
tfire is offline
post #2 of 28 Old 11-13-2010, 06:02 PM
fourplyn's Avatar
Red neck Ram Hydro assist...Works great..lol
Past jeep:
- 40" Pro Comp X-Terrain
fourplyn is offline
post #3 of 28 Old 11-13-2010, 06:04 PM
I have a $25 parts store replacement for a an old Dodge pickup, $10 for the bracket = good to go. I'm a believer that a high dollar steering stabilizer is not going to be an advantage to me. Though I'm curious on why it would be though..
post #4 of 28 Old 11-13-2010, 06:07 PM
Dr.Dirty's Avatar
Feedback: 21 reviews
Not running one, But what ever you do stay far away from the Rough country Dual setup..
Dr.Dirty is offline
post #5 of 28 Old 11-13-2010, 06:15 PM
I have a Fox. It's been sitting on the work bench since June. I the 5000km I've put on since switching axles I havn't found that I needed one.
Alaska-HWY JK is offline
post #6 of 28 Old 11-13-2010, 06:24 PM
fnc
fnc's Avatar
I have a thrashed stock stabilizer. I plan on replacing it with a Bilstein though.
I can taste your meat from all the way up here.
fnc is offline
post #7 of 28 Old 11-13-2010, 08:58 PM
StubEXrube's Avatar
Poly Performance. Works well. May be overkill- idk.
StubEXrube is offline
post #8 of 28 Old 11-13-2010, 09:00 PM
i have a banged up teraflex one that is now leaking yay! but im pretty sure my set up is dialed in so i dont even need to run it
BBirish is offline
post #9 of 28 Old 11-13-2010, 09:03 PM
fourplyn's Avatar
X2 on hearing the same about them.
Past jeep:
fourplyn is offline
post #10 of 28 Old 11-13-2010, 09:19 PM
XJK07's Avatar
Im running a TeraFlex one. Didn't really need it I guess. It works just fine.
XJK07 is offline
post #11 of 28 Old 11-13-2010, 09:34 PM
Heat'n and a beat'n...
STUPIDFACE's Avatar
Im running none. Getting PSC steering soon.
corey d
2008 JEEP...
STUPIDFACE is offline
post #12 of 28 Old 11-13-2010, 09:38 PM
R8R ROK's Avatar
I am all down for opinions but as my sons Relgion teacher tells him , you can say or believe whatever you want but please explain to me why you believe in your thouhghts.
FYI, I am not religious. I just worship the TOTONKA !!!!!!!!!!!
Oh yeah , I do ask because I have one and after running the CON my dual stablizers look Sarah Palins daughters legs all twistied up.
Cutts Crew
Orginal Quote from cjcraig7 "Every time I hang out with you Cutts fucks, one of you inevitably gets pissed and vandalizes my shit."
R8R ROK is offline
post #13 of 28 Old 11-14-2010, 04:52 AM
Dr.Dirty's Avatar
I have Whats left of two complete rough country setups laying in the scrap metal bin. If you never wheel it will probably work out of for you. The first one after multiple encounters with the trackbar one tsba was crushed shut, wich led to the brakcet on the axle spinning all the time resulting in the stab mounting bolt rubbing on the tie rod. Well th bolt rubbed a whole in the tire rod so i ditched it to scrap. Sfccotton had the same setup and his was holding up better until her ran the dusy and it reaked havok on his whole steering system wich im sure he will enlighten you more on that LOL
Dr.Dirty is offline
post #14 of 28 Old 11-14-2010, 08:44 AM
PIG
PIG's Avatar
Best bang for the bunk I think but my opinion is clearly skewed...
Fox is $55 more and pretty much the same thing. Bilstein is a little less but won't allow the user to tune the PSI of nitrogen internally.
PIG is offline
post #15 of 28 Old 11-14-2010, 08:48 AM
How necessary is it to tune the PSI on a steering damper?
What is your set at default compared to the Bilstein?
gcally is offline
post #16 of 28 Old 11-14-2010, 09:31 AM
This is what I did and it works:
SS + relocate it to the top
I got my Woods relocate stabilizer on. What a difference in location. This is just smart engineering. Why the factory hangs it on the bottom is beyond me. I used my new Monroe SS #SC-2960 that I painted yellow by the way and slapped a Monroe sticker on it. It came from O'Reillys in black paint form for $37.99. I had to grind some of the flair off the SS at the bracket to make it fit. Simple fix for a much bigger SS that doesn't cost much. Very happy with Woods products.
Their website:
http://www.jeepswag.com/jeep_jk_stee...kit/index.html
Old location:
New Location:
4x4x4 is offline
post #17 of 28 Old 11-14-2010, 09:34 AM
R8R ROK's Avatar
Thanks man , that is really helpfull. I am going to beef up or take mine off. I can't have that kind of stuff happening on the trails.
Cutts Crew
R8R ROK is offline
post #18 of 28 Old 11-14-2010, 09:54 AM
edivebuddy's Avatar
Here's mine from Off Road Only
edivebuddy is offline
post #19 of 28 Old 11-14-2010, 10:04 AM
BadAssJK's Avatar
As dialed in as you can get with a bent tie rod.
I have the fox s/s and will be the first to tell you I got it cause it looks sweet. I probably do not need one at all. I knocked the shredder valve off (due to the way it was originally mounted) and have had a hard time finding a place to refill it with nitro (tire shops want nothing to do with it) so its currently on but at 0 psi.
A s/s is almost like that skid row skid, 90% for looks.
BadAssJK is offline
post #20 of 28 Old 11-14-2010, 10:18 AM
PIG
PIG's Avatar
It all depends... I have found that every person likes it a little differently. That is why being able to tune it to your specs is an advantage. Ours are set @40 PSI, I don't know what the Bilsteins are set at.
PIG is offline
post #21 of 28 Old 11-14-2010, 10:59 AM
Iron's Avatar
Woods relocation bracket and a OME stabilizer for a TJ
Mike B
08' Jeep Wrangler
08' Dodge Avenger SXT (winter beater)
64' Plymouth Sport Fury(sold)
58' Triumph TR-3A(in 1,000,000 pieces)
Iron is offline
post #22 of 28 Old 11-14-2010, 11:23 AM
Stickerboy111's Avatar
I run a Rancho RS5000. Seems to be working well.
2008 Unlimited Rubicon JK
Detonator Yellow
2" Zone Offroad Spacer lift
SuperWinch LP8500
128CH Kenwood VHF
Cobra 40ch CB
Custom Axe&Shovel holder
Custom Jerry Can Holder
48" Highlift
Air Compressor
Rampage Grab Handles
Congo Rack
"Good roads bring BAD people, Bad roads bring GOOD people"
Was I banned? Hell Ya
Eddie is an Ass Clown
Stickerboy111 is offline
post #23 of 28 Old 11-15-2010, 10:02 AM Thread Starter
Yeah I think after all of this I am going to wait until I get the lift on and then see what all is going on with it. thanks for the input.
tfire is offline
post #24 of 28 Old 11-15-2010, 10:34 AM
PUDDLZ's Avatar
X2
PUDDLZ is offline
post #25 of 28 Old 11-15-2010, 03:43 PM
dtcc687's Avatar
do you need new mounts for the poly stabilizer? or does it mount of to factory mounts, or are new ones included? just thinking about picking one up soon.
Steel Blue 07 2dr
Jersey
Crew
dtcc687 is offline
