Check Engine light - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 11-12-2010, 09:42 PM Thread Starter
militaryman4455's Avatar
Check Engine light
My Jeep is throwing 2 codes right now after I sank it in frog hole at Rausch creek. I dont have any true ill effects from it but I would like to fix the problems so there are no long term effects on the motor. Maybe ya'll can help.
Its throwing the code for the dreaded evap canister (P 0440 I think) and its throwing the code saying that the Post Cat sensor is reading too rich. Im thinking that both of these are simply bad sensors from them getting wet and probably fried from frog hole but Im sure some of you will have some more insight.
Do I just need to replace the sensor behind the cat? And I have no clue what to do about the evap canister.
Oh yeah, just recently, it starting giving me a gas cap indicator. I have taken the gas cap on and off several times making sure its tight, I have no clue what to do about that either but Im not really too concerned about it.
Mod..Wheel..Break..Repeat
Criminals prefer unarmed victims:Μολὼν λαβέ
Originally Posted by cjcraig7 View Post
I think I understand your question - but I am a two door guy.
militaryman4455 is offline
post #2 of 7 Old 11-12-2010, 10:17 PM
BenFoo's Avatar
Did you try pulling the battery terminal for a few mins and doing a "system reboot" on the jeep's ecu?
BenFoo is offline
post #3 of 7 Old 11-12-2010, 11:58 PM
paramaniac's Avatar
If you got the code for the evap can and then got the gas cap notice, I'd wager that you've damaged the evap can/hose/gasket. If it is sensing a leak somewhere in the system that could throw those codes. You should check the can for cracks, make sure all the hoses are in place and intact. As for the gasket, I think it's behind the white connector.
As for the O2 sensor... I guess just replace it. Trouble is, there are, I believe, 6 O2 sensors on the JK...
Good luck
paramaniac is offline
post #4 of 7 Old 11-13-2010, 06:36 AM
dirtydog4x4's Avatar
Good luck
I've been to the dealer 3 times for this and they treat me like a 16 year old and tell me my gas cap is loose. I hate dealers!!
DIRTYDOG NETTING, SUN SHADES AND PET DIVIDER
dirtydog4x4 is offline
post #5 of 7 Old 11-15-2010, 10:01 AM
Victim Of Pain's Avatar
Guess it's time to update the warning sign...
Victim Of Pain is offline
post #6 of 7 Old 11-15-2010, 10:08 AM
crazychaser's Avatar
I've had both issues with mine (evap can and gas cap).
I took it to the dealer and both were covered under the warranty.
[Don't pretend you care what I've done to my rig]
crazychaser is offline
post #7 of 7 Old 11-16-2010, 11:23 PM Thread Starter
I have not tried doing the reboot yet. I thought about it but did not want to just clear the codes.... or lose my radio setting and all my progammed stuff from my procal. I guess Im just going to have to stop being lazy and do it though. Ill check all the connections on the canister, I already looked at it and it isnt cracked though, but one of the wires looked like the "casing" had come off. And I know the sensor is the post cat sensor, Im pretty sure there is only one so that should be easy, Ill just pull it and see if I can just maybe clean it or something. If not then Ill replace it. Where is the best place to get a new sensor?
