grill modd with winch bumper= overheat? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 11-11-2010, 04:13 PM Thread Starter
greenenvey's Avatar
id like to do the grill modd but i also have a front winch bumper im worried that the combo will possibly cause over heating issues? anyone have both ? id hate to do the mod and have to try to pry everything off if i have to remove the screen latter.
2010 rubicon. 3.5 rk lift. 37,s. 6.2 Ls3.
greenenvey is offline
post #2 of 5 Old 11-11-2010, 04:30 PM
I have both and two lights on top of the fairlead and have no sort of cooling issues.
post #3 of 5 Old 11-11-2010, 06:16 PM
Joneszj's Avatar
I have a winch mounted to the top of my bumper. And I did the grill mod about 3 years ago.
I never understood worrying about cooling, I have had no issues whatsoever.
The JK engine runs hot, it was designed to run hot. Sucks, but thats the way it is. The main thing to do if you are worried about engine temps is vent the hood in some way or buy an expensive aftermarket hood.
The winch and grill mod shouldn't change things that drastically unless you use some sort of thick aluminum for the grill mod. I used the plasticky gutter guard. Cheap, easy, and functional. And the rest of the front of the JK is plastic so why shouldn't the grill grates be plastic as well?
1972 Commando on Tons & 40s
Joneszj is offline
post #4 of 5 Old 11-11-2010, 06:32 PM Thread Starter
greenenvey's Avatar
the only reason i worry is because so much of it is blocked by lights, winch and grill insert , but thanks for the replys im glad to hear that it should be fine.. .. my jk dosent run hot?
post #5 of 5 Old 11-11-2010, 06:39 PM
Stock gauge is pretty much useless. It's pretty much set to read dead in the middle unless it's really getting warm. I think normal operating temp is in the 210-220ish range? Which is warm in general. But it's happy there, less emissions
my winch is up top too
