Floor Jack Question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 11-11-2010, 01:46 PM Thread Starter
Floor Jack Question
I saw a great deal on a nice 2.5 ton floor jack. Do you think its strong enough? Or should I hold out and spend some more $ and get a higher rated one?
Thanks!
myJK is offline
post #2 of 9 Old 11-11-2010, 01:57 PM
07unlimitedx's Avatar
2.5 tonne is good enough, I have a 3 tonne and 3000 lbs and both do the job no problem, just make sure you use jack stands.
steve
07unlimitedx is offline
post #3 of 9 Old 11-11-2010, 02:00 PM
Rerun's Avatar
How high does it lift? I have a Michelin that lifts 22" and its great.
Some jacks only lift 14" or so and that isn't high enough for our jeeps.
Rerun is offline
post #4 of 9 Old 11-11-2010, 04:22 PM
BryGuy's Avatar
x2
How high it lifts becomes even more important down the road, when your Jeep starts to grow up. Better buying a more expensive one now, rather than a cheaper one that you'll need to replace later.
2008 JK X 2dr. Std. Blk
BryGuy is offline
post #5 of 9 Old 11-11-2010, 05:06 PM
tkob1060's Avatar
harbor freight $80 and you can get a no questions asked replacement warranty for 2 years for like 20 bucks.
http://www.harborfreight.com/automot...ack-34271.html
tkob1060 is offline
post #6 of 9 Old 11-11-2010, 07:16 PM
I have that jack, it works well but the release sucks. Every time I try to let something down easy it slams to the ground.
gcally is offline
post #7 of 9 Old 11-11-2010, 07:31 PM
Mine does take some concentration and some grip for an easy release. But I've used snap on and high end jacks that had the same problems.
post #8 of 9 Old 11-11-2010, 07:48 PM
WINNAR!
DOOKEY's Avatar
I use the same brand in a 6 ton version. Release is the same. Works perfectly.
DOOKEY is offline
post #9 of 9 Old 11-11-2010, 09:36 PM
I got mine at Canadian tire, when nothing on it 2 pumps and it's at 23"... have had it 3 yrs now and no problems... 3000 lbs one lift 16".
