Replace rear wiper assembly - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 11-10-2010, 08:44 PM Thread Starter
I am in process of replacing my busted rear glass tonight, and am to the point where I need to re-install the rear wiper assembly. Problem is I have no idea how to get the wiper arm detached so I can get the new assmbly mounted. I have removed the plastic cover and the main bolt, but the wipr arm is still securely in place. Anyone know if it pulls straight off, or is it threaded and need to be twisted off? Help!!!
scotts43035 is offline
post #2 of 10 Old 11-10-2010, 09:12 PM
tkob1060's Avatar
it should pull off, never seen a wiper that twisted off. Its been long time since I had my hard top, does the wiper pivot away from the glass like the windshield ones do? sometimes you have to pivot them to be able to pull the arm off.
you removed a bolt or nut holding it?
tkob1060 is offline
post #3 of 10 Old 11-10-2010, 09:27 PM Thread Starter
Its driving me nuts. It looks like it should pull off....
See the pics below. THere is a shaft (which is a screw), the wiper arm, and a nut on top. The nut came off, and I can not figure out to get the stupid wiper arm off! Suggestions are welcome!
post #4 of 10 Old 11-10-2010, 10:06 PM
coilrod's Avatar
Subscribed because tree limbs have scratched my top and jammed in my third light ...only a matter of time. Can you try a gear puller or is there too much resistance?
coilrod is offline
post #5 of 10 Old 11-11-2010, 05:13 AM Thread Starter
I've pulled pretty hard
I don't think its something that should require that much force, and I don't want to break the wiper arm. It seems like there must be some kind of trick to getting this off, but I can't figure it out.
post #6 of 10 Old 11-11-2010, 05:34 AM
BigMike's Avatar
1. Remove wiper assembly from rear glass
2. Plug the hole in the glass
3. Throw wiper motor in the trash.
I bought a hard top and my Jeep isn't wired for any of it. No plans to do so. It's a fawking Jeep.
, Granite,
BigMike is offline
post #7 of 10 Old 11-11-2010, 06:06 AM
Vryce's Avatar
I've replaced the rear wiper motor in my old liberty, so this should be pretty close.
The arm will pull straight off but you're going to have to work for it. I used a screwdriver and then a box wrench to work the arm up the shaft (boy that just sounds wrong).
When you reassmeble. hook all the wiring up first and turn it on once to reset the motor to neutral. This will make sure that the arm is in the correct reseting position. A little anti-seize on the shaft won't hurt either.
Hope this helps you out. Oh Haynes Manuals are worth their weight in gold if you don't have one already.
Vryce is offline
post #8 of 10 Old 11-11-2010, 06:20 AM Thread Starter
Got it! Thank you Vryce!!!!
A little prying with a screwdriver underneath and it just popped right off. Thank you!
post #9 of 10 Old 06-15-2018, 01:44 AM
How did the prying affect the washer between the glass and the arm?
cb_hdhunt is offline
post #10 of 10 Old 06-15-2018, 09:08 AM
Treader's Avatar
Almost 8 year late to ask that question. How about you go and test it and get back to us?
2010 2 door manual sport
Treader is offline
