Headlights - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 04-09-2007, 08:19 AM Thread Starter
Mikey's Rubi's Avatar
Headlights
What are people doing to replace the headlights? Is there anything out there yet? The stock headlights are terrible but that is probably because I am just used to the IPF Fat Boys I had in my LJ.
Mikey's Rubi is offline
post #2 of 13 Old 04-09-2007, 09:14 AM
Broker by the Minute
MichaelW's Avatar
I went with full replacement of the lamps to E-Code lamps. I am running 85watt through some Marchals and the difference is night and day. However I had to alter the wiring to run such bright bulbs and the write up is here.
The company I got the lamps and bulbs from also sells Cibie brand which is a less expensive alternative as the Marchals are designed more for Rally racing.
MichaelW is offline
post #3 of 13 Old 04-09-2007, 02:39 PM Thread Starter
That looks awesome. Do the lights then use a switch to turn on? I am going to wait until sPOD finishes their product for the JK before I do that. Is there something less techinical like a direct replacement?
post #4 of 13 Old 04-09-2007, 05:06 PM
MichaelW's Avatar
Nope they still use the factory switch to turn on the lights hi and low beam as usual. I would contact Daniel in the link I gave in the first thread. He can tell you about alternatives and what might be a replacement with a little less work. He would know as this is what he does for a living.
MichaelW is offline
post #5 of 13 Old 04-12-2007, 08:28 AM
WikedLizard's Avatar
I should be getting my HID kit in the next few day or so. Will let yall know how they turn out.
WikedLizard is offline
post #6 of 13 Old 10-15-2014, 02:50 PM
For no good reason other than the fact that I was bored, I decided to resurrect the oldest thread I could add something to.
Truck-Lites!
2013 COMMANDO GREEN
6-Speed, A/C, 3.73's
Support the 2nd Amendment - It's your right!
MOLON LABE
Scott2373 is offline
post #7 of 13 Old 10-16-2014, 06:29 PM
conejo's Avatar
KC's!
conejo is offline
post #8 of 13 Old 10-20-2014, 03:08 PM
X2 on KC's. Improved beam pattern over the trucklites and can be found for only about $40 more.
Love mine.
rfr002 is offline
post #9 of 13 Old 10-20-2014, 08:15 PM
SoK66's Avatar
Love mine.
Thanks for that tip, just started looking at lights today.
SoK66 is offline
post #10 of 13 Old 10-21-2014, 05:07 PM
Love mine.
Every photo I see seems like the trucklites have more of that "black chrome" look than the KC's have you seen them side by side? I love the darker look of the JW speakers, but not so much the price point.
klif01 is offline
post #11 of 13 Old 10-22-2014, 10:44 AM
UnlimiDozer's Avatar
X2 on this. USMCDoc14 did a great headlight comparison some time back (you should search and read it!), and the Speakers came out to be (not surprisingly) the best light pattern available. Not sure they're twice-the-money good though. Been wrestling with this one myself. If the price point were even close, to me it would be no question. I'm sure there are some who would prefer a little more traditional look though, and the J W Speakers are anything but traditional.
My Build Thread:
I'm the NRA
JOIN HERE:
UnlimiDozer is offline
post #12 of 13 Old 10-22-2014, 11:19 AM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
Ahem!
https://www.jkowners.com/forum/showthread.php?t=187594
Better overall output, 300 less than the Speakers.
JKCTAZ is offline
post #13 of 13 Old 10-22-2014, 03:24 PM
I've tried HIDs in the stock housings, Hella's (halogen and HIDs), Cibies, HID Projectors, Hella's (again) and TL LEDs. By far the best I've had are the TLs. The Hella's were very good for what they cost (~120+ a harness). The TLs make my 10" rigid bar useless (I keep it just to piss off people who don't turn their highs off).
2012 Silver JKU Rubicon
5 speed auto, 4.10s
Riptide is offline
