First Fluid Change - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 11-05-2010, 05:08 PM Thread Starter
First Fluid Change
Hi,
First of all I know this topic is well covered and I did find what I need to know using the search function, but I need your opinion.
I have 2010 JK auto, it has about 10k miles on it and this weekend I'm going to change all the fluids to synthetic. This is going to be the first time I change the fluids ( except engine oil, do that every 3k).
My questions is, should I just drain and refill my tranny oil or should I also change the tranny filter?
I have an AUX aftermarket tranny cooler so I figure it will take an additional quart of oil, does that sound about right?
Since the Jeep only has 10k miles on I figure engine flush is not required to go from regular to synthetic.
VKJK is offline
post #2 of 12 Old 11-05-2010, 05:34 PM
Your factory automatic transmission fluid is already synthetic...ATF+4
post #3 of 12 Old 11-05-2010, 05:47 PM
07unlimitedx's Avatar
I'm going to change mine to Amsoil, which I think is better the dealer stuff.
07unlimitedx is offline
post #4 of 12 Old 11-05-2010, 10:20 PM Thread Starter
Right, but should I pull the change the tranny filter?
I'm doing a little wrench time with a Jeep, installing rockers, HID lights, and all the fluids.
VKJK is offline
post #5 of 12 Old 11-05-2010, 11:46 PM
10K seems way too early to change tranny fluid and filter. I forget what the manual has to say about the schedule but I know its way down the road. I changed my fluid at 55k and am still running the origional filter.
post #6 of 12 Old 11-06-2010, 05:03 AM
I guess I would if I was dropping the pan. ATF+4 is pretty good stuff, but it's your call.
What part of North Dallas are you in?
post #7 of 12 Old 11-06-2010, 08:08 AM Thread Starter
Plano / Frisco area
Sent from my SPH-D700 using Tapatalk
VKJK is offline
post #8 of 12 Old 11-06-2010, 08:12 AM Thread Starter
It is early but I thought original oil might have metal shavings in it, knowing Chrysler assembly quality it might have an empty beer can.
VKJK is offline
post #9 of 12 Old 11-06-2010, 08:44 AM
Your going to get alot of mixed opinions on this. It is very early to change the tranny fluid, BUT, if you are going thru the pain of dropping the pan, my opinion is to change the filter while your in there.
09rubicon is offline
post #10 of 12 Old 11-06-2010, 08:46 AM
Plano / Frisco area
Cool, if you need a hand with anything I'm up in Providence Village. 10mi east of Denton on 380
post #11 of 12 Old 11-06-2010, 09:12 AM Thread Starter
Thanks, I might do this tomorrow. How is your day tomorrow?
VKJK is offline
post #12 of 12 Old 11-06-2010, 09:39 AM
TrailDuty.com
PhilD's Avatar
Way too early for a trans fluid change and you already have syn fluid in it. However, if you want to do it, go ahead and change the filter while you are at it.
FWIW I use an external filter and change the fluid by disconnecting the hose at my aux cooler, crank the engine over, add some more fluid, and repeat until done.
https://www.jkowners.com/forum/showthread.php?t=28958
PhilD is offline
