Gear Oil - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 11-04-2010, 02:17 PM Thread Starter
pizzaman's Avatar
Gear Oil
So i went to the store, found the row of 80W-90 gear oil that the manual recommends, and grabbed 3. However, whoever was stocking the shelves put an 85w-140 in the mix. stupid me didnt check all three bottles until i got home.
so the question is if i do the majority of the diff with the 2 bottles of 80w-90 and then top off the last 12 oz with the 85w-140 will that be bad? do I just need to go back and exchange it? im asking because the jeeps in the garage with no gear oil and id have to get a ride up there. thanks.
pizzaman is offline
post #2 of 5 Old 11-04-2010, 02:24 PM
gold knight's Avatar
What's that give you about 82w-110? I'd go for it. I can't imagine it being a problem. The '08 manual calls for 75w-140 rear for towing so you should be fine.
gold knight is offline
post #3 of 5 Old 11-04-2010, 02:38 PM
jkx0778's Avatar
are they all the same type (synthetic or conventional)? if so, you should be fine. the difference is the 85w-140 gives you protection up to higher temps. the lower viscousity rating (80 vs 85) shouldn't be enough to make any real difference.
________________
jkx0778 is offline
post #4 of 5 Old 11-04-2010, 02:41 PM Thread Starter
pizzaman's Avatar
yea theyre both the same type, brand and all, just different viscosity ratings.
thanks for the quick responses guys. this is my first time dealing with gear oil
pizzaman is offline
post #5 of 5 Old 11-04-2010, 04:48 PM
spleify's Avatar
Yep, like the others already said, you should be fine!
NRA Member!
ΜΟΛΩΝ ΛΑΒΕ
/l , [____],
l----L -OlllllllO-
()_) ()_)------)_)
2007 Rubicon
spleify is offline
