2010 Lifetime Maxcare and Duratrac 315/70/17 Questions. - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 10-28-2010, 02:12 PM Thread Starter
Situation:
I have a 2010 2 door 6-speed Rubicon that I would like to run the Duratrac 315/70/17 on without rubbing to much and keep the Lifetime Maxcare (Bumper to bumper).
Ideas:
I know suspension lifts will make warranty work a pain with most dealers even if its the Mopar lift. So question is will the RC 1.25 body lift (doesn't change any suspension), Spidertrax wheel spacers or new rims and flat fenders be it PSC, Bushwacker, Xenon or Nemesis be able to run those tires without rubbing to much. Anyone in a similar situation that is able to run those tires on stock suspension?
So far my idea is after reading alot:
1) Rough Country Body lift of 1.25" for manual transmission (no boot cutting).
2) Flat fenders (Bushwacker uses factory mounts).
3) Extended bump stops.
4) Cut stock rubicon rock rails by 2" or so.
5) Wheel spacers or new wheels (4.5" or less backspacing)
6) Pound on the rear wheel well pinch seams.
Any other suggestions without voiding the lifetime warranty.
Mallow
Mallow is offline
post #2 of 8 Old 10-28-2010, 02:27 PM
pluke the 2's Avatar
Originally Posted by Mallow View Post
Situation:
Ideas:
Mallow
I think you'll be good running the 315's with your planned mods. Around town you'll be better off then out flexing where you will encounter some rubbing.
Anything goes with dealers, if they can point the finger at your tires they will and there goes your warranty. I would check with the dealership in question that may or may not void your warranty to be sure.
No one on here is going to tell you what will void your warranty, it's all about the dealer.
pluke the 2 is offline
post #3 of 8 Old 10-28-2010, 02:32 PM Thread Starter
Yeah I talked to several around and all basically said the same thing. 35" and less will not affect the warranty. But anything that changes the suspension will. I can't seem to find a lift friendly Jeep dealer within 1hr drive it seems.
Mallow is offline
post #4 of 8 Old 10-28-2010, 02:41 PM
Yeah, to be honest, it's almost better to do the lifting after your main warranty is expired.
I bought a bone stock two door brand new, threw some tires on it, took it to the dealer for a "Recall" and they blamed my tires as the main cause for my brake lines leaking.
post #5 of 8 Old 10-28-2010, 02:43 PM
Maxcare is not run through Jeep. Maxcare will approve or deny claims. If they are expensive enough, or multiple repairs you can expect a inspector to look over the vehicle. Your modifications (tire size and wheel spacers primarily) may be caught there and the claims declined if relevant (driveline, wheel bearings, suspension, etc)..
-BMW tech that has dealt with this and other various aftermarket warranties
post #6 of 8 Old 10-28-2010, 03:15 PM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
Cancel the warranty and use the refund for mods?
RiverCityOffroad is offline
post #7 of 8 Old 10-28-2010, 04:32 PM Thread Starter
Would like to keep the warranty thanks though Just wanted to work with/around it for the time being.
Mallow is offline
post #8 of 8 Old 10-28-2010, 04:34 PM Thread Starter
The warranty is the unlimited miles/years lifetime maxcare. I bought it since this will be my winter vehicle forever. The jeep has some issues getting me to and from my house last winter so working mainly on fixing that. When/if I want to seriously mod a Jeep i'll buy a bone stock used/salvaged X and start from the ground up.
Mallow is offline
