Best tires? And lift? - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By coilrod
post #1 of 9 Old 02-02-2020, 07:03 PM Thread Starter
Torenv's Avatar
I have a 2015 jeep willys 2dr and i want to get bigger tires. i have the stock 255/75 r17 tires that comes on the willys with 3.73 gearing and rubicon suspension that comes stock on the willys.I want to get 33x12.5 r17 or 305/65 r17 BFG KO2s on some Daytona style steelies. I mostly do highway driving in the very rainy city of Vancouver Bc, Do i need to get a lift/fender trimming/regearing ect. or will i be fine running stock. If anyone has pictures of their rig with a similar setup! Thanks
Torenv is offline
post #2 of 9 Old 02-02-2020, 08:40 PM
For a daily driver you should be fine with out gearing or a lift. IF you rub is would be minimal and at full lock while you are at full articulation.
post #3 of 9 Old 02-03-2020, 08:33 AM
Will Scarlet's Avatar
Have you tried searching this forum? Questions like this have been asked hundreds, if not thousands, of times, so I suggest searching first.
Good luck...
2011 Sahara Tan Rubicon 6 Speed
TR HD17 Beadlocks, BFGoodrich A/T KO2 34x10.50R17, Teraflex HD Tire Carrier, Clayton 2.5" Overland Plus Lift, Fox 2.0 reservoir shocks, and more to come...
Will Scarlet is offline
post #4 of 9 Old 02-04-2020, 12:27 AM
I ran 35's on my 2016 Rubicon while 100% stock, for about 4 weeks, while I was saving money for the lift install. Had zero issues with clearance on the streets. After the lift, I put 40,000+ miles on the stock gears with 35's. If you have Rubicon suspension and 3.73's, you should be fine.
L/¯¯\\_ |"/¯¯¯(ºlllllllº)
_(¯))==))..(¯))==))
Last edited by marcspaz; 02-04-2020 at 11:53 AM. Reason: Corrected misinformation.
marcspaz is offline
post #5 of 9 Old 02-04-2020, 06:01 AM
levelling kit from Teraflex + your 33" KO2 choice will make the Jeep laugh at anything - including rain of Vancouver - and you & your wallet happy.
post #6 of 9 Old 02-04-2020, 06:47 AM
coilrod's Avatar
Talking
Why lift at all?
J. Dub likes this.
coilrod is offline
post #7 of 9 Old 02-04-2020, 08:02 AM
Originally Posted by marcspaz View Post
I ran 35's on my 2016 Rubicon while 100% stock, for about 4 weeks, while I was saving money for the lift install. Had zero issues with clearance on the streets. After the lift, I put 40,000+ miles on the stock gears with 35's. If you have Rubicon ride height and 3.73's, you should be fine.
The rubicon does not have a special ride height.
post #8 of 9 Old 02-04-2020, 11:51 AM
I know. Not sure why I typed that. Glad you mentioned it so I don't confuse new owners and people doing research.
He mentioned the Willys having the same suspension as a Rubicon, which has different performance characteristic than a Sport or Sahara, for example. Just wanted to let him know he will be fine with that suspension and tire combo.
_(¯))==))..(¯))==))
marcspaz is offline
post #9 of 9 Old 02-13-2020, 07:38 PM
I run 285/70-17 (33's) on stock suspension. Fine for the road but I imagine I'd have a clearance issue with any serious offroading. Someone else recommended a leveling kit. I think that's a great idea. I helped a buddy install a teraflex 2"/1" leveling kit on his JKU that already had 33's and it made a huge visual impact while driving/riding like stock. Rancho also makes a 2" kit that completely leveled my JKU with new springs and either non-adjustable or adjustable shocks for not a lot of money. New shocks made a huge impact on the ride quality of my wife's jeep, smoothing it out and eliminating the jiggly ride.
Boosthead is offline
