Noise when breaking - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 01-14-2020, 04:14 PM Thread Starter
Ninomarie's Avatar
Just went from stock tires on my 2016 wrangler to cooper discoverer s/t maxx 255/80/17 tires. Notice a small rumbling noise when I brake. Brakepads and rotors all in great shape, did not hear the noise before putting on new tires. Any ideas on what this may be caused by?
Ninomarie is offline
post #2 of 10 Old 01-14-2020, 06:17 PM
  • lug nuts torqued to spec with your torque wrench, not the tire shops?
    • you gonna tell us if it is coming from front or rear or which side?
  • Have you jacked one wheel up at a time & played with it to see if you can manually recreated the rumble?
  • Having someone in the driver seat applying brake as you turn it with your hand is useful.
  • is it when the brakes are engaging or when it is fully stopped?
  • have you hit the welcome Room to introduce yourself & your Jeep?
post #3 of 10 Old 01-14-2020, 11:50 PM
coilrod's Avatar
A rock or leftover lugnut in the dust shield?
coilrod is offline
post #4 of 10 Old 01-14-2020, 11:58 PM
Random Dude
Are you certain you're not just feeling / hearing the lugs of your new tires?
Have you had mud tires before, and know what that sounds & feels like?
ExWrench is offline
post #5 of 10 Old 01-15-2020, 04:40 AM
funfred's Avatar
This.
funfred is offline
post #6 of 10 Old 01-21-2020, 07:24 PM Thread Starter
Ninomarie's Avatar
Noise when braking
I have not, but wouldnt that sound be all the time and not only when braking?
post #7 of 10 Old 01-21-2020, 07:27 PM Thread Starter
Ninomarie's Avatar
I got new rims and tires to replace my stock rims and tires,
This is coming from the front doesnt seem to be a specific side I only hear the noise when engaging brakes
I will try what you have suggested and I introduced myself in the welcome room sorry I am new to this site and didnt know about this until you mentioned it.
Thank you
post #8 of 10 Old 01-21-2020, 09:05 PM
Random Dude
Originally Posted by Ninomarie View Post
. . . wouldn't that sound be all the time and not only when braking?
Knobbier tires feel smoother at higher speeds because you're rolling over the mini peaks and valleys faster. When you brake, more weight is transferred to the front wheels and the steering is more loaded, so you'll feel more of the lugs. Also when slowing down, wind noise and other NVH (=noise, vibration, and harshness) are reduced so the tire NVH is more noticeable.
That being said, your noise description is a tad vague:
. . . a small rumbling noise when I brake.
If not tire lugs, it could be ABS kicking in, IBS kicking in, wheel bearing failing, chemtrails, or maybe even aliens . . .
ExWrench is offline
post #9 of 10 Old 01-22-2020, 12:21 PM
BigTB's Avatar
What pressure do you have the new tires set at? I have the ST Maxx tires, and they do rumble a tiny bit more when the pressure is on the low side. Not aired-down low, but just on the low end of normal.
Also, I always notice it more when braking. You don't have the sound and vibration from the engine that you have when accelerating, and it does get smoother once you are moving faster.
That doesn't mean you shouldn't ensure all else is good (lug nut torque, brakes, etc.).
BigTB is offline
post #10 of 10 Old 01-22-2020, 03:09 PM
you can go piss up a rope
snout's Avatar
Do you see any rub marks on the inner wheel or on tire weights?
Dust shield touching anything?
If you jack up the front, can you freely spin the wheel and hear anything?
Do you like piña coladas?
y’aller quenchin' with beer
snout is offline
