Hey everyone new member here looking for some help for my issues I have a 2013 JK SaharaUnlimited and I’ve been experiencing “floating” steering which has gotten pretty bad it’s worse at high speeds where it just wonders but my steering wheel is straight the trucks just wanders left and right even at low speeds I see myself having to pull back into the lane due to the wandering, I recently upgraded my Tie rod and track bar to Yeti and have a fox 2.0 steering stabilizer and also upgraded my front upper and lower ball joins to TeraFlex so I’m assuming it would be the control arms any advice would be greatly appreciated
Need more information to even begin. For starters:
Did this issue recently appear? Gradually or suddenly?
Before or after changing out the front end components you listed?
Any other modifications done within the suspect time period?
Do you know that all the components recently replaced were installed correctly?
Are you mechanically inclined enough to make that determination?
Are the joints tight on your drag link (not listed as recently replaced)?
Have you verified no loose fasteners or slop in drag link, tie rod, track bar, and control arms?
Have you checked your alignment (or had it checked)?
Is anything bent?
What tires are you running, and at what pressure? Are the tires wearing evenly?
x2 on what ExWrench is asking, more info would be helpful here, but I'll take a stab in the dark.
Wander is usually caused by a lack of proper caster angle, or misalignment...BUT I see you listed your ball joints as recently replaced. Some ball joint are installed "tight" and take a bit of time to wear in properly. It's a matter of the joint not moving freely enough for the caster angle to work it's magic and re-center the wheel. During this period the steering can seem flighty or wander-y. You end up manually making a million small corrections, that normally are smoothed out by the caster doing it thing.
I'm NOT sure, however exactly how to test for this. Maybe jack it up, and disconnect the drag link and tie rod to see if each wheel turns freely ?
The good news is that if that's it, it should get better after a few hundred miles.
If it's not... then the alignment seems suspect. Maybe the control arm bushings? Control arm bolts loose? Steering box mounting broken/loose?
Shooting totally in the dark here.
Report back with more info. Also, drop by the welcome room if you have not already and introduce yourself.
Thanks for the replies fellas, let me get into detail and see if it can help.
I run 35s on a 3in lift
Recently upgraded were Tie Rod - Drag Link(forgot to mention) - TrackBar
Equipped with Fox 2.0 steering stabilizer
I upgraded my front Lower and Upper ball joints on Aug 2018
This problem seemed to have occurred gradually and if it did occur it must of been easily ignored because within the last week it became more noticeable and gotten worse over the past weekend and this week. The upgrades I’ve done to the front end happened around(Sep 26) of this year and I took it to a 4x4 shop who I was recommended to and the mechanic was very savvy which he said he mentioned when I picked up my truck he also took her to get an alignment.
The wandering was not noticeable when I drove off, I’ve been meaning to get under there and check the bushings of the control arms but haven’t got a chance due to work but that’s first on my list. Thanks again appreciate the replies
I second this thought. your symptoms mimic some I had long ago when I discovered the more affordable & supposedly " HD Adjustable front trackbar " from RR was actually flexing and bending as I would turn my wheels. It can be of great assistance to sit on ground in front of the Jeep running & have someone turn lock to lock for you to observe all linkages functioning in that capacity, fwiw.
balljoints can be crazy stiff when new.
I can't stress strong enough how often people overlook the super important need to grease HD new balljoints . it preserves their life AND prevents the cintered-ball on the stud from running dry & partial-bind locking your turning enough to cause similar symptoms to what you're seeing.
my last consideration would be OPs new Fox 2.0 SS. When they're new, some of these gas charged steering dampeners tend to push a Jeep's steering to driver/left side since the charge is positive & it wants to always decompress . That's why I preferred the nuetral resistance of my former Fox ATS* , even at it's higher price-point.
* ( fwiw, I have one of these for sale in my " parts" thread on here in our 'For Sale' section . I have been surprised no body has snagged it for as cheap as I have it priced. I only stopped using it after upgrading to hydraulic assist.)
Hubs and bearings is a place I would look. I used to have a bobblehead feel to my steering. Jacked up both sides and noticed play in front wheels that should not have been there.
Ok fellas I finally got the chance to check and see if I could find anything that was loose but in my opinion everything looked good, I’m still running my stock control arms and have about 62k mi on the Jeep so I also checked the bushings and while they look how I expect they would look with 62k mi of use I didn’t see any major cracking or excessive play so the last thing I’m assuming it will be is my caster is out of wack which should suggest I should invest in adjustable control arms
Add to cart for pricing. Yes it sounds like the caster is off. Also make sure you run the 28 PSI suggested to see if that helps. Take off the stabilizer and run it. Regrease the ball joints. Make sure the mechanic torqued do the arms etc when on the ground under the vehicle weight. One more thing, if you drive 90%+ on pavement and at higher speeds, get the caster correction brackets. They keep the lower arms more flat for better surface ride. Lots of good advice above.
Really double check the wheel bearing. I had the same problem and checked them once but they seemed ok. I was rotating the tires a little later and with the tire off I wiggled the hub. A small amount of play. Remedied that and the steering floating was all gone.
Related Threads
JKOwners Forum
2M posts
62.8K members
Since 2007
