TPMS light erratic - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 11-08-2019, 07:08 PM Thread Starter
Jesse Dupont's Avatar
TPMS light erratic
My tpms light has always been on solid. Donít have any sensors. Recently the right side of the gauges started to dim then a chime would sound and the tpms would flash with an occasional low tire warning in place of odometer.
2009 JKUR 3" BDS,RK pro tie rods
Jesse Dupont is offline
post #2 of 4 Old 11-09-2019, 06:40 AM
you can use a tuner like procal or flashpaq to disable tpms but sometimes , even on JK's that have long had the sensors removed , will experience what you are from a wire on the harness from clockspring being time-worn or rubbed it's insulation off from daily drive vibration.
check those.
also, gps , Bluetooth devices , lowrance , misc RF frequencies can cause the thing to flash but yours ( w/ tht dash section illumination fading or waning) sounds more like bad wiring. Have you cleaned & maintained your battery terminal posts / clamps & verified it's condition for the Winter?
hope that helps.
post #3 of 4 Old 11-09-2019, 04:55 PM Thread Starter
Here is a vid of it happening
https://youtu.be/gLASxd8-4eU
post #4 of 4 Old 12-01-2019, 06:43 AM
chipflyer's Avatar
Following
chipflyer is offline
