Jeep stuff I've learned - June/July 2019 - JKowners.com : Jeep Wrangler JK Forum
 4Likes
  • 3 Post By j3ff3ry_j33p
  • 1 Post By Fklein6768
post #1 of 5 Old 07-31-2019, 02:47 PM Thread Starter
I wasn't able to post a June OR a July "things I have learned" tip.
Here's a couple of things I thought someone may find useful sometime...
(tho' I've probly mentioned them before... ) .
__________________________________________________ __________________________________________________ __________________________________________________ __________
1st -
A common topic involving aftermarket parts & the JK/JKU which seems to frequently popup involves the greasing of
aftermarket dual-cardan driveshaft's centering-ball ; this necessary service often requires a shaft be removed at one flange/yoke ,
just to let ya reach a well hidden, flush zerk fitting to squirt 5-7 pumps of grease in it. Can you say PITA?
I use that thing. It's called a "right-angle needle-point grease coupler" fitting.
I got it from McMaster-Carr
(I have seen it online, too).
I just jack front pssgr wheel up & use my leg-foot to reach + slowly turn the lifted wheel ; that clocks the DC-joint to right
spot for it to be open enough to let that coupler fit in and press into that zerk on both Tom Woods 1310 & a 1350 driveshafts,
It works & is a great time saver that I've used for years.
2nd -
I saw several newer posts recently talkin about this somewhat infamous topic again.
JK owners know that almost any dragink or tie-rod can flop or roll once its tierod ends loosen w/ use.
We also know there's vast numbers of us who turn to Synergy Mfg for beefing up our Jeep's steering linkages , among other parts .
Synergy's updated model draglink now comes w/ a single-plane TRE to prevent frwrd flopping of the DL.
It's pretty common knowledge that clocking the rod-ends into misalignment on the Synergy Mfg tierod is how to mitigate the roll of it, however I
found this wasn't totally effective when I still had the original 4131 TREs ( note- this was all before Synergy intro'ed the 4139-L - that single-plane TRE - which now ships on their draglinks for JK/JLs)
that were on my earlier 8001 model Synergy DL . It would still roll-forward.
Try this:
acquire one or two Universal Replacement Urethane Tie Rod End Boot -
I get mine from Currie
but I think they are probably just reselling ProThane or Energy Bushings.
I found that if I ran one of those boots ( set , stacked ) installed ON TOP of the silicon, grease-filled boot that was already on it @the draglink's knuckle-side TRE, it stopped almost all of - leaving just the necessary amount so that it wouldnt bind - of the DL flop.
Here is pict of mine as I'm describing it:
I also futzed-around & found if I used one on that same pssgr side & for the Synergy Mfg 8002 tierod ,here,too, it eliminated most of that links flop-movement, too.
Furthermore, if I ran them on top of both tie-rod TREs, it completely eliminated any unwanted rolling forward. This was when I had the Fox ATS stabilizer ,prior to moving to assisted steering.
This was just something I had tried out of desperation ( I ripped a boot) & I found
that it prevented the movement effectively ....
Happy Trails
post #2 of 5 Old 08-05-2019, 11:02 AM
good tips especially the needle point grease coupler. i need to order one soon.
Chris85xlt is offline
post #3 of 5 Old 08-21-2019, 06:46 PM
Fklein6768's Avatar
Fun fact for August. If you idle while running the ac and dont have any carpeting left you can heat up a snack cake while waiting for soccer practice to finish/just leave it on the floor for a few-
j3ff3ry_j33p likes this.
www.4x4s-pod.com
Fklein6768 is offline
post #4 of 5 Old 08-22-2019, 04:04 AM Thread Starter
Thumbs up
THIS.
... comment , posted-by our brother, @Fklein6768 , is exactly the type of
information I envisioned these threads being compromised-of when considering the thread.
well done , sir.
(no, I mean my Jeep ,floor heated -sweet bread mini-cake by Entenmann's...I want it freakin' well done! yum )
post #5 of 5 Old 08-24-2019, 12:27 PM
Fklein6768's Avatar
August update for JKU folks and those that have a soft top with no velcro left and dont run windows. For $20 or $5 if your thrifty and make ur own, the tj clover patch convert a top does work with a jku.
Plan b was to just cut the rear corners off but I would still need the straps to support the rear of the top.
Didnt feel like doing the leg work so I spent the $20....
Worked fine. Add/next onto the list is a better stereo so I can actually hear some music while cruising.
www.4x4s-pod.com
