2008jk c2200 code - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By SpartanToJo
post #1 of 3 Old 07-20-2019, 08:56 AM Thread Starter
2008jk c2200 code
I just picked up a 2008 four door wrangler without all brake lights on dash. red brake light,abs,esp,bas,traction control. If have a handheld scan tool with abs. It throws c2200 code. Abs module internal fault. From what I gather the service manual says if the code comes right back after clearing to replace module. My issue is the code does not come back right away, but only after I drive 100+ feet. I have removed the wheels and brakes and cleaned everything. Also checked all associated wire harnesses. My experience tells me it may be related to a bad wheel speed sensor, however I don't have a scan tool capable of live data to check wheel speed sensors while driving. Any ideas?
post #2 of 3 Old 09-10-2019, 10:39 AM
I am having the same issue with my jeep, same here, same code same warning lights.Lights came on the dash-lights after I locked up breaks trying to avoid a collision in front of me. ABS, break, ESP BAS, and traction control wiggle lines widget. Cleared codes, and they come back after I drive 10 mph. Anyone have a solution?
Shad is offline
post #3 of 3 Old 09-10-2019, 01:33 PM
Wheel speed sensors are easy to replace and reasonable cheap. Your Jeep is more than a decade old so I'd just replace them all. Should be less than $100 for all four. If cost is a real issue, buy them one at a time. Rock Auto has fronts for about $12 and rears for about $19.
SurfnSnow likes this.
SpartanToJo is offline
