3.8 Stroker - JKowners.com : Jeep Wrangler JK Forum
 6Likes
  • 1 Post By rich6700
  • 3 Post By j3ff3ry_j33p
  • 2 Post By SoK66
post #1 of 7 Old 05-31-2019, 11:37 AM Thread Starter
3.8 Stroker
hey guys new to this forum just wondering if anyone had any experience with a stroker kit for the 3.8. I know that 505 offers one but I have not heard good things about their company. Was just wondering if there was any other companies out there that make a 3.8 stroker kit. Thanks guys
cgibbons330 is offline
post #2 of 7 Old 05-31-2019, 01:22 PM
JKommuter's Avatar
https://www.jkowners.com/forum/modif...roker-kit.html
https://www.jkowners.com/forum/engin...ker-motor.html
https://www.jkowners.com/forum/modif...it-hensco.html
Hate to be a "search is your friend" guy, but I found these in about 20 seconds using that little google search in the upper right corner of this page.
2009 JKU
JKommuter is offline
post #3 of 7 Old 05-31-2019, 01:23 PM
rich6700's Avatar
Spend the extra money and put a Chevy engine in it.
coilrod likes this.
rich6700 is offline
post #4 of 7 Old 05-31-2019, 08:43 PM
coilrod's Avatar
Good luck with that.
Originally Posted by thedirtman View Post
Running 37's as a daily driver is dumb
coilrod is offline
post #5 of 7 Old 06-01-2019, 10:26 AM
If you would go to allpar.com & read about the Chrysler 3.3l v6 from the early nineties , you'd learn that as it was becoming longer-in-tooth , as the expression goes, or later in it's production run , you'd come to learn that the 3.8l v6 60 engine that's in 07-11 Jeep JKs actually IS a stroker powerplant
& has barely any cylinder wall remaining that's got enough thickness which you coukd bore ,hone ,stroke or increase the volume of much further.
coilrod, ExWrench and rockystock like this.
post #6 of 7 Old 06-03-2019, 02:22 PM
Pmedic920's Avatar
Nuff said.
Pmedic920 is offline
post #7 of 7 Old 06-04-2019, 03:51 PM
SoK66's Avatar
Learn to live with the 3.8L as it is and enjoy life. My '09 JKUR has been on 37s for nine years and 70,000 of its 77,000 total miles, just 5.38 gears and a Procal to set the PCM. Will cruise at any speed limit just fine and kills it on the trails. The Little Engine That Could can only be reliably bested by going full V8 swap, and IMHO you'd be better off putting the money into a newer Jeep. Sad that you can't do inexpensive engine swaps any longer, like the GM V8 I saw today in an '85 Scrambler. Sigh.......
Mr.T and j3ff3ry_j33p like this.
SoK66 is offline
