Help needed - rear axle stuck, won’t come out - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By j3ff3ry_j33p
post #1 of 8 Old 05-15-2019, 06:16 PM Thread Starter
Hey there! I need some help/advice. I’m trying to do a rear axle seal replacement on my 2013 Jeep JK Sahara Unlimited but I can’t get the driver side axle out. I’ve got the ABS off, the parking brake all off, and the diff open. I have also tried put the old brake rotor on backwards and wailing it with a hammer and it doesn’t budge. Even a slide hammer didn’t work. It feels like it’s locked into place near the brake end. I have tried to do some research and thought it might be a C-clip axle but can’t see any and couldn’t find a way to remove the pin in the diff. Any helpful advice would be great or some insight. Thank you. Going to try the rear passenger side axle on Friday.
lugsandjugs is offline
post #2 of 8 Old 05-15-2019, 06:45 PM
Random Dude
Did you remove the nuts from the 4 studs holding the wheel bearing retainer plate in place?
ExWrench is offline
post #3 of 8 Old 05-15-2019, 07:30 PM Thread Starter
Yup, I removed the 4 nuts from the back
post #4 of 8 Old 05-15-2019, 10:04 PM
rich6700's Avatar
You may have a bent axle tube. Are you using a slide hammer with the axle flange attachment?
rich6700 is offline
post #5 of 8 Old 05-22-2019, 03:41 AM
Laggy's Avatar
Both sides stuck?
Saw one time an axle wouldn't come out because the axle breather was threaded in too far, had worn a groove and was preventing axle from moving out.
Laggy is offline
post #6 of 8 Old 05-22-2019, 05:38 AM
Any update ,OP?
I will go with slightly twisted splines at carrier-end or bent shaft.
Shall we set small wagers on if this guy will come update his thread or y'all think he is gone way before this morning....
I ,for one , will truly miss him if he's gone. Doesn't it seem like only a week ago that we had just witnessed the blossoming of friendship w/ @lugsandjugs ?
post #7 of 8 Old 05-23-2019, 12:17 AM
ronjenx's Avatar
I'll go with the seal being stuck in the outer end of the housing.
ronjenx is offline
post #8 of 8 Old 05-23-2019, 05:04 AM
I've seen that more than the twisted splines but
what got me thinking further-on down the possible causes chain was him saying he'd flipped rotor around & banged on it w/ the BFH. Usually that'll clear those wedged or seized seals when I've seen similar occur.
Maybe OP didn't eat any HGH or spinach or Wheaties that morning ?
Similar Threads
2009 Jeep Rubicon axle stuck, Really stuck! A girl her dog and her JEEP JK General Discussion 25 02-20-2019 10:59 AM
Don’t know what to do, NEED HELP! 09_rubicon Modified JK Tech Dept. 12 05-11-2018 03:28 AM
Key won't come out of ignition! Mitchw123456 JK General Discussion 15 03-12-2012 01:32 PM
Rear axle shaft won't come out siphon6 Modified JK Tech Dept. 14 10-09-2011 11:48 AM
