Dana 44 Oil Change Question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 10-29-2018, 11:27 AM Thread Starter
Yesterday I changed the front and rear Dana 44 on my 08 Rubicon and i have a question.
The specs call for 2 quarts of fluid in each axle. However when i drained them, the back had 1.5 quarts and the front 1.
I inspected the ring and pinion gears and no damage on the teeth, no shavings etc.
At first i thought they had been improperly filled by the last owner but when i went to refill sure enough the back took 1.5qt plus 4oz anti slip and the front 1qt.
Should I leave them like that since they been like that with no damage for a while or should I buy a new cover with a higher drain plug?
I have a very mild 2.5" lift with 35's and i tried to compensate for the change in angle by doing it on my slanted driveway but there's no way I'm fitting 2 quarts in there.
Anyone got advice on this?
Casanova956 is offline
post #2 of 9 Old 10-29-2018, 11:33 AM
Fill to just below fill hole level. Oozing out is too much
libordemise is offline
post #3 of 9 Old 10-29-2018, 11:34 AM
In stock diff cover. Aftermarket cover needs diff. Amount. Get it? Dif? Different? Differential? It's funny...
post #4 of 9 Old 10-29-2018, 12:04 PM
Treader's Avatar
Looks like you have a taller lift which has rotated your axles as well. That in itself will cause you to fill less fluid in there with the stock diffs. I recently did changed gear oil (granted a 30/44) and put in 1.35 and 2.35, respectively.
2010 2 door manual sport
Treader is offline
post #5 of 9 Old 10-29-2018, 06:01 PM
The rubicon e-lockers don't require friction modifier.
Front JK Dana 44 = 1.35 quarts
Rear JK Dana 44 = 2.375 quarts
That's according to chrysler, I just changed the diff fluid in my 08 Rubi and it was pretty close to that amount with aftermarket diff covers.
hmskyles is offline
post #6 of 9 Old 10-30-2018, 07:08 AM
^^^^^^what he said^^^^^^^
Do not overfill ! You will have oil all over the place .
Damage to the seals is also possible , E:Lockers need no additive , they are electrically actuated mechanical lockers .
I can't tell you how many times I've seen a puddle of gear oil under the drivers side front of a Jeep , and the smell of gear oil around one , then the smile of the proud owner with the look on his face "hey I just changed my own diff's fluids '' Without knowing what I'm doing .
Do the due diligence before you do the deed , it will cost you less money , but you won't learn the hard lesson .
un lupus is offline
post #7 of 9 Old 11-08-2018, 10:28 AM
SoK66's Avatar
OP your fill quantities are incorrect. Refer to your owners manual. The Rubicon front D44 holds roughly 1.4 quarts, the rear about 2.4. In my experience you can’t get those amounts into the axles via the fill holes in the covers. When I had stock covers I would add gear oil to the bottom of the fill hole, put in the plug, then put the remainder in via the breather fitting on the axle.
SoK66 is offline
post #8 of 9 Old 11-08-2018, 10:46 AM
ronjenx's Avatar
Regarding the differential fill quantities, I pay no attention to the numbers. The important thing is to make sure the diffs are filled to the correct level, which is just a bit over the bottom of the inside of the axle tube. That's where the OEM covers' fill holes would put it with no lift. If lifted, the fill hole rotates downward, so you would have to finish filling from the top as mentioned above, by SoK66.
With aftermarket covers that have a much higher fill hole, using a zip tie as a dipstick works to see the level of the fluid.
ronjenx is offline
post #9 of 9 Old 11-09-2018, 05:54 AM
^ what @ronjenx said , seconded....
The updated container solution which Amsoil now includes for it's gear lube rocks for this filling issue that's being discussed here in...
