2008 Wrangler- doors unlocking on their own/interior and headlights staying on - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 10-18-2018, 07:01 AM Thread Starter
Hi all! I'm a new Jeep owner and so happy I found this forum!
I just bought my 2008 Jeep Wrangler X and I am so happy with it! But I am in desperate need of answers, so any help/advice would be greatly appreciated!
Last night she started unlocking the doors on her own and the headlights and interior light would come on. The lights stayed on for about 30 seconds. The unlocking is completely sporadic and there were intervals where it happened every 2 minutes, but then it didn't do it for a few hours.
I've read a few of the threads posted here where other owners were having the same issue and I was wondering if anyone has a solution?
I'm pretty sure the previous owner replaced the TIPM, but I've read that some people are on their second or even third.
Could this just be a battery/electrical short issue?
All she's been doing so far is the unlocking thing, but I've read the problems can be much, much worse if it is the TIPM; I'm scared to drive her for now until I know whats going on.....
HELP! What should I do?
nola535 is offline
post #2 of 3 Old 10-18-2018, 08:22 AM
rockystock's Avatar
Recommend carefully removing the TIPM. If the last owner replaced it at least once, there's probably a good chance one or more of the connectors may have been damaged. I broke one of mine during an engine swap; replaced it with a new connector from
http://connectors.dcctools.com/home.htm
It wasn't cheap, but worth it for some peace of mind.
The TIPMs themselves don't have a good track record either. They're not watertight. If it appears that the TIPM was exposed to a lot of water, mud etc. It may be worth replacing, but definitely check the connectors first. Could just be that one of them needs to be pushed in a bit. Also take a good look at all the tipm pins. Good luck!
rockystock is offline
post #3 of 3 Old 10-23-2018, 08:36 AM
DarkKnight's Avatar
Mopar Connection Repair Kit
+1
Also check your battery connections, loose/damaged connectors make JK's do weird things.
DarkKnight is offline
