Atlas Four Speed - JKowners.com : Jeep Wrangler JK Forum
post #1 of 16 Old 09-29-2008, 06:20 PM Thread Starter
seer's Avatar
Atlas Four Speed
Got home on Friday to find two large boxes sitting on the porch! I ordered the 1:1, 2:1, 2.72:1 and 5.44:1 setup with the electric low switch.. Scheduled install date: The week of 11/23. I'd take pictures now, but who wants to see a couple of boxes?
seer is offline
post #2 of 16 Old 09-29-2008, 06:38 PM
Openly Hostile
Awesome! Not many people have put an atlas in the JK yet, looking forward to seeing it installed.
Jason
SDMF is offline
post #3 of 16 Old 09-30-2008, 08:36 AM
TrailDuty.com
PhilD's Avatar
Very nice
PhilD is offline
post #4 of 16 Old 09-30-2008, 09:02 AM
mcnaught6's Avatar
i've never understood why they chose the gear ratios for their 4-speeds the way they did.
the 2.1:1 and 2.72:1 are too close together. if you go with the other model, the 10.xx is waaaayyy too low.
if they'd make one with a 2:1, 4:1 and 5.44:1, i'd buy it.
mcnaught6 is offline
post #5 of 16 Old 09-30-2008, 09:04 AM
Administrator
HITMONEY's Avatar
Subscribed.
HITMONEY is offline
post #6 of 16 Old 09-30-2008, 09:36 AM
TrailDuty.com
PhilD's Avatar
[quote=mcnaught6;40917]the 2.1:1 and 2.72:1 are too close together.[/quote[X2
I'd like 10:1, wouldn't use it often but would be nice to have.
PhilD is offline
post #7 of 16 Old 09-30-2008, 09:54 AM
mcnaught6's Avatar
no doubt some would use the 10:1. i just wouldn't think that it would be useful to very many.
post #8 of 16 Old 09-30-2008, 10:04 AM
I have 6.5-1 in my Samurai. Being that low is awesome. 10-1 would be even better. I'm holding out for the crawl box for the auto to come out.
DO NOT DO BUSINESS WITH SHAFFERS OFFROAD. YOU WILL BE SORRY YOU DID..
igofshn is offline
post #9 of 16 Old 09-30-2008, 10:16 AM
Their 4 speed case is two units stacked together, a 2 speed case with a 2.72:1 reduction unit. You can get a 2 speed case with either a 2:1 or a 3.8:1 and then with the 2.72:1 reduction unit you end up with either 1:1, 2.0:1, 2.7:1 & 5.4:1 or with 1.1, 2.7:1, 3.8:1 & 10.3:1. That is why they have those gear ratio combinations.
If you have a RLE42 transmission, Advanced Adapters will offer the RubiCrawler this spring. It is a 2.72:1 reduction unit to replace the tail shaft of the transmission. With that unit, I would have 1:1, 2.72:1, 4:1 & 10.88:1.
https://www.jkowners.com/forum/showthread.php?p=27550
n8it is offline
post #10 of 16 Old 09-30-2008, 10:16 AM
Openly Hostile
I'd love to have a 10:1 for the rocks.
Jason
SDMF is offline
post #11 of 16 Old 09-30-2008, 10:41 AM
I can remember two times last spring in Moab that I would have used 10:1. And I know I would use 2.7:1, if I had it.
n8it is offline
post #12 of 16 Old 09-30-2008, 10:53 AM
exactly
the 2.72:1 reduction unit on the 4 speed is basically, if not exactly, the same thing that the "RubiCrawler" is.
To get the "RubiCrawler", AA basically took the front reduction unit off of the 4-speed and is using it to go in front of the NV241OR as the tailhousing of the tranny
paragon is offline
post #13 of 16 Old 09-30-2008, 11:10 AM
TrailDuty.com
PhilD's Avatar
I think a few people are anxiously awaiting the RubiCrawler, I know I am.
PhilD is offline
post #14 of 16 Old 09-30-2008, 11:15 AM Thread Starter
seer's Avatar
Originally Posted by paragon View Post
exactly
It's also the basic gear ratio for the Sahara and X. I use it a lot and really like it. However, there are times when I need something lower for both rocks and steep declines. I don't think I'd ever use a 10:1, but I'm thinking the 2:1 could be pretty handy in 2wd snow conditions. That's why I went that route. If bad comes to worse, I can always put in the Rubicrawler as well. Think of all the levers and buttons for that setup...
seer is offline
post #15 of 16 Old 09-30-2008, 11:44 AM
You already have the "Rubicrawler", it's part of the 4speed setup.
the 4-speed has the little doubler on the input just like the "Rubicrawler" would add as a doubler to the input of the stock t-case
paragon is offline
post #16 of 16 Old 10-05-2008, 10:59 AM Thread Starter
seer's Avatar
Here's a little tease for ya'll.
49 days until install.
seer is offline
