2015 JKU Rubi help - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 03-20-2017, 09:30 AM Thread Starter
2015 JKU Rubi help
Newbie here and need the pros advise. I am wanting to install the Terraflex 2.5 lift and add 35's to the mix. I have looked at many posts here but need to have more reassurance. Can I one, use the stock 17" rims and second, do I need spacers?
Brandon
roughneck720 is offline
post #2 of 6 Old 03-20-2017, 11:13 AM
mvjeeper's Avatar
Brandon
You shouldn't have an issue. My 2 door is on an old 2 inch lift with 35s and no spacers. I've only rubbed on the back a few times. and that was on some pretty intense Rocks/trails.
This is my Signature
mvjeeper is offline
post #3 of 6 Old 03-20-2017, 12:01 PM
Rubi-8's Avatar
Will work just fine.
07 JK-8
08 2dr Sahara
17 Gobi Recon
Rubi-8 is offline
post #4 of 6 Old 03-20-2017, 04:27 PM Thread Starter
Thanks to you both. Any recommendations on what tires to run as it appears as I will have to run narrower tires then what I thought due to cupping possibilities
post #5 of 6 Old 03-20-2017, 04:50 PM
mvjeeper's Avatar
If you want good on and offroad tires, duratracs or KO2s. If you're looking for strictly mud tires then I'm not sure.
as far as wideness, I run 315/70/r17s with no issues of cupping.
Most people run that size as well. 35 x 12.5 seems to be fairly common.
mvjeeper is offline
post #6 of 6 Old 03-21-2017, 06:00 AM
Rubi-8's Avatar
Second that. With a narrow wheel you can run lower tire pressure and your tires will not cup. Best way to find your correct tire pressure is to perform the chalk test.
07 JK-8
08 2dr Sahara
17 Gobi Recon
Rubi-8 is offline
