Rock Krawler Mid Arm 2.5 X-Factor question - JKowners.com : Jeep Wrangler JK Forum
 4Likes
  • 1 Post By ALASHA
  • 1 Post By Rb6700
  • 1 Post By ALASHA
  • 1 Post By crf
post #1 of 12 Old 03-03-2017, 03:18 PM Thread Starter
crf
Ok, I'm planning on trading in my Chevy High Country in on a new JKU Rubicon in a few weeks. I'm currently planning my build and have just a couple of questions. I am planning on getting the RK mid arm 2.5 x factor lift and running 35's with flat fenders. I know I will need to regear but will there be anything else I need to do to the jeep? I'm specifically wondering about any drive train modifications which i may or may not need to plan for. I'm a pipeline inspector and will be running my jeep off road almost every day for work and then playing a bit on the weekends. I need my vehicle to be as bulletproof as possible due to the nature of my job and would rather get it right the first time rather than waiting for stuff to break before upgrading. This will be my first jeep and my first lifted vehicle so my knowledge is limited to the internet reserach i've been able to do. As a total noob, your input will certainly be appreciated!
crf is offline
post #2 of 12 Old 03-03-2017, 03:23 PM
Get a new front drive shaft and request 4.10 from the dealership and you should be fine. Also Mopar makes a lift kit that they can install for you and avoid any hassle with warranty vs the RK kit. I'd also recommend axle reinforcement on the front
Sent from my Pixel using Tapatalk
Jkbroc is offline
post #3 of 12 Old 03-03-2017, 04:08 PM
ALASHA's Avatar
You dont need to get driveshafts on a JKU with an RK 2.5" lift. The stock shafts will do just fine.
Getting C gussets is always a safe upgrade and relatively cheap.
Also you will need to figure out bump stops which are included if you get one of the x factor kits with RK's shocks
crf likes this.
ALASHA is offline
post #4 of 12 Old 03-03-2017, 05:59 PM
If you disconnect with 2.5" lift you rub the boot off your front driveshaft at full droop
Jkbroc is offline
post #5 of 12 Old 03-03-2017, 06:49 PM
Rb6700's Avatar
Here are my thoughts. I don't know how deep your pockets are but if your like most people your going to need to build it in stages. The rk kit is a good kit the only additional part I would get is a jks rear track bar location bracket. It is my personal opinion that it's just a better piece than the on that comes with the kit. Gearing I'd go with 4:56's. Now depending on your preference your going to need a locker for the front, do this with the gear change. Now depending on you pocket book you can either do an axle truss or axle sleeves at the same time. A must is some type of skid plate for the oil pan and transmission. Now here are the rest of the stuff that will need to be replaced as cash allows. Chrome molly axles front and rear, diff covers, front drive shaft and rear. Oh and a rear locker I would do at the time of the gear change. Your going to need wheels with the tires unless you want to use wheel spacers with your stock wheels. And some type of programmer to reprogram the computer. Good luck with your build.
Pissing off my wife since way back
crf likes this.
Rb6700 is offline
post #6 of 12 Old 03-03-2017, 07:53 PM
ALASHA's Avatar
Yep the boot wont last but the driveshaft will without it. No need to drop another 1K+ at this point for a pair of driveshafts (or ~500 for just the front if that was where you were going with it).
Disclaimer:
Prices may vary depending on who you go with.
ALASHA is offline
post #7 of 12 Old 03-03-2017, 08:06 PM
ALASHA's Avatar
OP said he was leaning towards a Rubicon so he should be getting lockers right from the factory.
Curious why you like the JKS bracket over RK?
You will need some sort of programmer to adjust for tire size.
35s arent that big of a jump. As JKBroc said, I think you can get away with 4.10s so order it with them and see how you like it. If its horrible for you, then jump to 4.56
The need for engine/trans skid plates and upgraded axles really depends on what you consider "playing on the weekends." I got away with a lot (and I mean a lot) on 37s running factory shafts. In fact, the only thing that forced me the upgrade the rear shafts was sliding sideways into a curb during a snow storm. The front shafts never got damaged but my front axle was sleeved and gusseted. Again these upgrades will depend on your level of playing but I wouldnt put these in the must do category right off the bat.
Just the opinions of another shmuck on the interwebz.
crf likes this.
ALASHA is offline
post #8 of 12 Old 03-03-2017, 08:19 PM
Rb6700's Avatar
My bad I mist have missed reading he was looking at a Rubicon. New rubicons come with 3:73. 4:10 are now an option. Yes you can get away with not having a lot of that crap. I don't know how he wheels but he was asking about reliability and those parts are a good insurance policy to have. I stand behind having a skid plate as a must have for any kind of wheeling. There are only 6 bolts that hold the Trans pan on, you just tap that pan on a rock and you'll have problems.
Rb6700 is offline
post #9 of 12 Old 03-03-2017, 09:44 PM
ChuckTheRipper's Avatar
That's only if he gets a lame automatic.
ChuckTheRipper is online now
post #10 of 12 Old 03-04-2017, 03:45 AM
That totally depends how long your shocks are
CrazyLarry is offline
post #11 of 12 Old 03-04-2017, 06:07 AM
If you get the shock lengths recommended from RK, disconnect and have a "lame automatic" you rip the boot. How long it last depends on your wheeling.
Jkbroc is offline
post #12 of 12 Old 03-04-2017, 09:24 AM Thread Starter
crf
Thanks for the info guys! For what it's worth my pockets are fairly deep and I can do pretty much everything all at once. I'm planning on getting a 6 speed manual for what its worth. My "playing" on the weekend will be what I consider moderate. I'll definitely be doing the sleeve/gussets when I regear. Already planning on skid plates, wheels tires, rockers, programmer, winch, etc. I'll definitely look into some differential covers as well.
Rb6700 likes this.
crf is offline
