Broken front track bar mount - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 02-21-2017, 04:33 AM Thread Starter
Donut707's Avatar
So this past friday i had an interesting day. i was on an of ramp when i hear a very loud bang and the jeep stopped turning and started going straight! when i was able to stop the jeep i had ended up half on a curb blocking the rest of the off ramp. once i pulled the seat out of my ass i got out to see WTF had happened. at first i didn't see anything, so i hop back in to get out of the way. i get going and the jeep is super loose i start to slow down and hit the brakes and death wobble , so i pull off and give the jeep a better look now that i'm safely out of the way. i look at the front track bar mount and its cracked almost completely off .
I bought the jeep with 60K on it and it already had a procomp 4 inch lift with 35's on it. i had an issue with the track bar mount before (it cracked a bit lower on the mount and i added a plate and re welded it) so after another 60k of mostly highway driving and some weekend warrior wheeling if broke at the frame( as you can see in the above picture. i was lucky enough to get it towed to a local off road accessory shop and they got me back on the road by the next day. the shop cleaned up the re welded it back on , but suggested a more permanent fix. they suggested replacing the old garbage with just a new stock mount (they said a drop bracket was not needed for a 4 inch lift) . this is the route i will most likely take but i think an adjustable track bar . does anybody make an after market front track bar mount? and what have you guys done to beef up your track bar mounts
Donut707 is offline
post #2 of 11 Old 02-21-2017, 04:45 AM
Artec trac bar mount. It should be used with their truss for more strength.
post #3 of 11 Old 02-21-2017, 07:04 AM Thread Starter
Donut707's Avatar
Gunny
I need the UPPER mount , the one under the steering gear.
this looks promising but i will still need to remove and replace the stock upper track bar mount.
Wrangler JK Front Trackbar and Sector Shaft Reinforcement Kit
Donut707 is offline
post #4 of 11 Old 02-21-2017, 07:25 AM
There is this one as well. It bolts to the existing trac bar bracket so you will have to trust in your stock bracket a little.
SYNERGY MANUFACTURING*::*Jeep JK*::*Synergy Jeep JK Front Track Bar Brace
post #5 of 11 Old 03-07-2018, 04:30 AM Thread Starter
Donut707's Avatar
FINALY FIXED for real this time
So my track bar mount cracked again, I'm not surprised just look at that shit show above. so a friend of mine hooked me up big time. i already had a synergy mfg 3217 track bar frame bracket. He was able to get it welded up and it solid.
Do no harm but take NO SHIT
Donut707 is offline
post #6 of 11 Old 03-07-2018, 04:44 AM
you waited a year to fix the bracket or were just band aiding it along for a year?
post #7 of 11 Old 03-07-2018, 09:58 AM Thread Starter
Donut707's Avatar
I was band-aiding it for a while. now I think i've got it fixed for good.
Donut707 is offline
post #8 of 11 Old 03-07-2018, 11:01 AM
Yeah that bracket is pretty stout.
post #9 of 11 Old 03-12-2018, 04:34 AM Thread Starter
Donut707's Avatar
A hint of bump steer
So I'm getting a hint of bump steer. it will happen a low speed (like over speed bumps ) but it rides and drives fine at highway speed. the jeep does have a dropped pitman arm. the angle of the drag link and track bar are very close. The new track bar mount is not in the stock location, so I'd like to how far off I am from stock. if someone could measure their stock upper track bar mount id appreciate it.
Donut707 is offline
post #10 of 11 Old 03-12-2018, 04:43 AM
is that OEM trackbar youíre running with your drop bracket ? Film that assembly while youíre turnin wheel lock to lock then watch the video of your steering being cycled back and forth; if ya have bigger heavier tires I bet that trackbar is flexing as you turn the wheel if itís the stock TB.
post #11 of 11 Old 03-12-2018, 08:33 AM Thread Starter
Donut707's Avatar
ill try to get a video of it turning lock to lock. I'm running a Teraflex adjustable HD track bar up front and out back. I'm thinking that the new bracket bolt location is lower than the stock but higher than the shit show I had before.
Donut707 is offline
