2014 JK Lift - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 12-09-2016, 04:09 AM Thread Starter
2014 JK Lift
I have a 2014 JK with a 3.5" Pro Comp Lift and 37's. I'm wanting to lift a little more and not wanting to buy another suspension lift. I'm considering coil spring spacers. Any recommendations?
Southerland1 is offline
post #2 of 10 Old 12-09-2016, 08:13 AM
JKommuter's Avatar
Welcome aboard.
Guys are probably going to want more info. What are you trying to accomplish for instance.
My recommendation:
If you are running stock fenders, I would cut those or replace with flat fenders before going over 3.5".
2009 JKU
JKommuter is offline
post #3 of 10 Old 12-09-2016, 02:58 PM Thread Starter
Have some front end sag now, installing new front and rear bumpers soon, also winch in front and swing tire carrier in the back.
post #4 of 10 Old 12-09-2016, 03:02 PM Thread Starter
Another shot
post #5 of 10 Old 12-09-2016, 03:15 PM
sprockwell's Avatar
Are you asking for a recommendation of brands for coil spacers? This is not one of those decisions you have to sweat over. Figure out how much higher you want to be and buy the appropriately sized spacers. I'd pick the cheapest.
'13 JKU | 3" Synergy, 37" KO2
sprockwell is offline
post #6 of 10 Old 12-10-2016, 05:02 AM Thread Starter
2" front &1" rear, should the shocks and brake line drops from the 3.5" suspension have enough travel for the spacers?
post #7 of 10 Old 12-10-2016, 06:04 AM
coilrod's Avatar
Your pic shows zero percent of the components. Procomp is pretty budget so I assume no adjustable arms or trackbars? What backspace?
Sagging as in riding on your bumpstops or tires occasionally hit the front bumper when dropping off ledges at full stuff?
Spacers will lift you. If you flex out now without ripping and brake or sensor lines that won't change. Not adding shock or coil length just means you sit higher into your usable travel.
Consider your suspension as a whole. (Not just a money hole but as a whole unit). Raising your center of gravity for appearance is a questionable decision.
Originally Posted by thedirtman View Post
Running 37's as a daily driver is dumb
coilrod is offline
post #8 of 10 Old 12-10-2016, 06:46 AM Thread Starter
Considering the AEV or Rubicon Express 4.5 in the future for a better lift, at only 3K, it's def worth it. No other components were added with this lift besides what came with. Just looking to make up for what the extra weight will add for right now.
post #9 of 10 Old 12-10-2016, 09:33 AM
JKommuter's Avatar
As stated above all the spacers are pretty much the same. Spend as little as you can.
For a future lift I think you could get better lifts. Consider Synergy, Rock Krawler, and Metal Cloak. Everyone tends to recommend what they have.
If I were going to drop 3K on a new lift I would be looking at this Metal Cloak 3.5"
2009 JKU
post #10 of 10 Old 12-11-2016, 11:38 PM
Aside from RK and Metal Cloak, Teraflex is another good lift kit for the JK's.
karlduke is offline
