Teraflex 2.5" Lift - JKowners.com : Jeep Wrangler JK Forum
 2Likes
  • 1 Post By clos0791
  • 1 Post By Dirtysocks
post #1 of 12 Old 10-09-2016, 11:56 AM Thread Starter
Teraflex 2.5" Lift
I'm finally looking to put a lift on my 2014 JK. Been looking at a few brands and kinda set on the Teraflex. I've read a lot of great reviews on it for the price and they have been around for a while. Does anyone have pictures of the this same lift on there jeep with either 33" or 35" tires? How does it ride compared to stock? I rarely go off road so its mainly a mall crawler. Also is it a good idea to get an adjustable front trac bar to re center the axle or is it not needed with this little of lift? Thanks!
Sent from my SAMSUNG-SM-G870A using Tapatalk
yamaharider529 is offline
post #2 of 12 Old 10-09-2016, 05:48 PM
I have the Teraflex Budget Boost 2.5, it rides like stock on my 15 jku. 33 inch K02s tires look great.
Sent from my SM-G928V using Tapatalk
yamaharider529 likes this.
clos0791 is offline
post #3 of 12 Old 10-09-2016, 06:24 PM
Teraflex 2.5" Lift
I have the Teraflex budget boost that comes with the shock extensions & rear trackbar bracket on my JK w/ 35s.
If you're not going to wheel, I would suggest staying with 33s. With the 35s & this lift, the handling definitely changes & you'll need to do more to get the handling back closer to stock.
Here're are some pics:
Stock -
Stock w/ flat fenders -
Stock w/ flat fenders & 35s -
And finally, with the Teraflex lift added -
The last two pics are what you really wanted, but thought you'll like to see the progression.
2014 Black JKR on 35s
Dirtysocks is offline
post #4 of 12 Old 10-09-2016, 06:30 PM
Also wanted to add that I went with the lift because the 35s were rubbing at extreme flex when wheeling.
post #5 of 12 Old 10-11-2016, 08:46 AM Thread Starter
Thank you guys for commenting I really appreciate it! The Teraflex kit I'm looking at comes with longer coils instead of spacers. I wasnt sure what the budget boost lift was. The price of the one im looking at is $750 and comes with Teraflex shocks. Your jeep looks perfect with 35's. Kinda worried 33's might look small after the lift.
[I
post #6 of 12 Old 10-11-2016, 08:47 AM Thread Starter
Would you happen to have any pictures of yours with the 33's? Thanks
post #7 of 12 Old 10-11-2016, 09:13 AM
This is the budget boost that I have - https://teraflex.com/shop_items/528f...d962f416e72d7e
SKU: 1355210
post #8 of 12 Old 10-17-2016, 02:47 AM
When it comes to apperance, 35's are a better choice. What gears do you have? It can also help you in deciding the right tire size.
karlduke is offline
post #9 of 12 Old 10-17-2016, 07:10 AM
dbrooks's Avatar
Here's mine with the Teraflex 2.5" coil lift you're talking about getting. I also added control arms and a Rock Krawler front track bar. The track bar was necessary because the bushing on the old one was toast.
It's a great lift and I have no complaints. I would definitely recommend it.
dbrooks is offline
post #10 of 12 Old 10-20-2016, 07:07 AM
EODrubi26's Avatar
Another option is rubicon express 2.5. That's the lift I just went with. From research on the forum i found that they are def. comparable lifts and a lot of guys like RE over teraflex due to the rebranded bilstien shocks over the teraflex 9550s. Also the springs are apparently made by the same company. With that all being said. I think either way you'll be very happy with the teraflex if you go that route. Also tire wise I just went with the new grabber x3 and I have no lift currently. Just running flat fenders. No rubbing on road but the tolerances are very close regarding my rock rails.
EODrubi26 is offline
post #11 of 12 Old 02-21-2017, 08:03 PM
[I
A few months dated, but I'm wondering if you ended up going with some combination of this setup? Budget boost, budget boost with shocks, 33s, 35s...?
zachsch is offline
post #12 of 12 Old 02-22-2017, 09:30 AM
Ive been running the TF 2.5" coil lift for 6-7 year now. The coils has sagged some over the years but still pretty happy with it.
I didnt like their sway bar endlinks. the bushings kept wearing out and i eventually replaced them with JKS
I didnt use the old style rear trackbar drop bracket with the kit (new kit uses a beefier trackbar bracket). instead i got one from RK
I didnt use the bump stop extensions either cause it had too much drop. at ride height it was almost riding on the bump stops.
Basically only the coils are left from the kit lol
JKUR with armor, bumpers and winch on 35's. I also have Synergy's f&r adjustable track bars and lower control arms
edit: forgot to mention i tossed the brake line relocation brackets too. The rear TF sway bar endlinks with the bolt pointing inward caught the relocated hardline and bent it into a "U" while out in Moab. Replaced with Crown braided lines. The over sized bump stop extensions that i left out might of prevented this though
Chris85xlt is offline
