2008 Auto, 84K miles, tranny slipping. - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 03-05-2016, 07:21 AM Thread Starter
Todd00000's Avatar
Is it time for a rebuild already?
She's had an easy life, very little towing and off road, and synthetic tranny fluid.
Todd
First Jeep the govt hasn't owned.
Todd00000 is offline
post #2 of 10 Old 03-05-2016, 07:26 AM
ronjenx's Avatar
By synthetic, do you mean ATF+4? That's the only thing you should be using in your 42RLE, if that's the transmission you have.
First thing to check is the fluid level; warmed up, engine idling, in park.
ronjenx is offline
post #3 of 10 Old 03-05-2016, 07:47 AM
as ronjenx stated, test the level of fluid while warmed-up , in park & running ; I , too, just had 84k in a 4 door '11 w/ 42rle and have only run Mopar ATF+4 up to 80k ; i moved to the Amsoil ATF+4 recently -not for any reason except I bulk order oil,filters, gear oil from them so might as well get it all from the same place - & have no issues. I would immediately suspect it is low or needs a fluid flush and filter if you haven't done so yet. I cant recall the interval the User Manual states to have it changed but I follow the severe use intervals on mine; I flushed and changed tranny fluid at 60k as I recall, but I am OCD about things like this . I wheel mine hard but am checking oil & tranny fluid levels every gas fill-up ( weekly at least...) I can taste when it is time to change my motor oil. heh
let us know what the level read when you checked it warm....pix are awesome.
post #4 of 10 Old 03-05-2016, 12:00 PM Thread Starter
Todd00000's Avatar
It had Amsoil ATF4 for a 50K miles, now it has generic synth ATF4 in it that was just replaced and is still slipping and has more hesitation before changing gears.
Todd
post #5 of 10 Old 03-05-2016, 12:42 PM
ronjenx's Avatar
If it's not one of these, that could be part of the problem:
Please note Licensed ATF+4® Brands have been updated as of December 2015.
Advance Auto Parts ATF+4®
Amalie ATF+4®
AutoPride ATF+4®
Auto Extra ATF+4®
AutoZone ATF+4®
Carquest ATF+4®
Castrol ATF+4®
Castrol Transmax +4 ATF+4®
Castrol Transmax ATF+4®
Chevron ATF+4®
CITGO Transgard ATF+4®
Federated Auto Parts ATF+4®
Great Wall ATF+4®
Havoline ATF+4®
MAG 1 ATF+4®
Mobil ATF+4®
Mopar ATF+4®
Motomaster ATF+4®
Motorlife ATF+4®
NAPA ATF+4®
Northland ATF+4®
O’Reilly ATF+4®
Parts Master ATF+4®
Parts Plus ATF+4®
Pennzoil ATF+4®
Pennzoil Platinum ATF+4®
Petro-Canada ATF+4®
Prime Guard ATF+4®
Proline ATF+4®
Pronto ATF+4®
Pure Guard ATF+4®
Quaker State ATF+4®
Rallye ATF+4®
Ravenol ATF+4®
Sinopec ATF+4®
STP ATF+4®
Super Tech ATF+4®
Tutela Transmission Force4 ATF+4®
Value Tech ATF+4®
Valvoline ATF+4®
ronjenx is offline
post #6 of 10 Old 03-05-2016, 12:50 PM
Gib
If it looks life this, then yes your tranny is slipping.
Gib is offline
post #7 of 10 Old 03-05-2016, 07:51 PM
Comfortably Numb
RubiCajun's Avatar
ROTFLMFAO
RubiCajun is offline
post #8 of 10 Old 03-05-2016, 11:46 PM Thread Starter
Todd00000's Avatar
It had and has the correct ATF.
Todd
post #9 of 10 Old 03-05-2016, 11:47 PM Thread Starter
Todd00000's Avatar
To the original question, what kind of mileage are we getting from the early Auto trans?
Todd
post #10 of 10 Old 03-06-2016, 05:38 AM
ronjenx's Avatar
I have 116,000 miles on mine; no problems. I have changed the fluid and filter twice since new.
But then, it has had only ATF+4 in it from the list above; MOPAR and Valvoline.
ronjenx is offline
