Upper and Lower Control Arm Lengths - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By kjeeper10
post #1 of 18 Old 02-21-2016, 10:55 AM Thread Starter
CamoCop's Avatar
Does anyone know the proper lengths for the rear upper and lower control arms for a 4 door JK with 3.5" of lift? I can't find the info anywhere and I'm trying to save time instead of the doing the trial and error process.
CamoCop is offline
post #2 of 18 Old 02-21-2016, 11:26 AM
kjeeper10's Avatar
Theres no set numbers. Id say 20" lowers , 18" uppers unless you want to move the axle back more then 1/4
Lowers set wheelbase, uppers pinion and thats going to be different jeep to jeep and 2/4 door.
kjeeper10 is offline
post #3 of 18 Old 02-21-2016, 12:49 PM Thread Starter
CamoCop's Avatar
It's there any negative implications for moving the rear axle back further? I was thinking the axle needs to go back about an inch to be even close to center.
CamoCop is offline
post #4 of 18 Old 02-21-2016, 01:07 PM
kjeeper10's Avatar
No .. But most manufactures will to clear a 37" plus.
In all reality wheelbase change is minimal. I find .5 back to be a nice compromise. Anymore the coils can bow. On a 2 door pinion correction runs the swaybar links up against the UCA mounts.
post #5 of 18 Old 02-21-2016, 08:05 PM
JKO Dickhead
Asmmns's Avatar
What lift do you have...and what is the manufacturer's recommended length ??
__________________
CURE SMA !
Asmmns is offline
post #6 of 18 Old 02-22-2016, 08:37 AM Thread Starter
CamoCop's Avatar
I'm running a 3.5" RE lift with a 1.25" BL and am going to 40" tires. right now I'm on 37" tires and clear but the 40's will be close. I've already trimmed the rear pinch seam down. oh, this is a 4 door also. with this lift and trimmed fenders I have more than enough lift height for the 40's but my rear axle is far from centered in the fender well. when I ordered the adjustable rear control arms to center my rear axle, I also ordered the spring wedges to help with any spring bow.
2011 Wrangler Unlimited Rubicon
- 3.5" Rubicon Express lift /w 1.25" BL
- 5.38 Yukon gears
- 40" Pro Comp MT2's
- Lot's of extra's
CamoCop is offline
post #7 of 18 Old 02-22-2016, 08:48 AM
kjeeper10's Avatar
I would go for .5 to .75
post #8 of 18 Old 02-22-2016, 08:54 AM Thread Starter
CamoCop's Avatar
so to move my rear axle back say .75", do I just adjust my rear lower control arm .75" longer than the factory arm or is that not how it works?
- 5.38 Yukon gears
- Lot's of extra's
CamoCop is offline
post #9 of 18 Old 02-22-2016, 08:55 AM Thread Starter
CamoCop's Avatar
sorry for all the questions. I've never messed with adjustable control arms before.
- 5.38 Yukon gears
- Lot's of extra's
CamoCop is offline
post #10 of 18 Old 02-22-2016, 09:05 AM
kjeeper10's Avatar
I found the easiest way to do it.
-Match lowers 20.5 (+ .75)
- remove lowers and install new arms (leave the bolts loose)
- jack up axle and place on stands
- use jack under pinion to take load off and remove uppers
- set driveshaft angle -2 using jack
- remove tires
- take one upper, bolt up frame side and adjust joint out to the axle mount (bolts should slide in/out with ease)
- do the same with the 2nd upper
- lower jack and recheck pinion angle
- tighten everything up
- mount tires
- drop to ground
j3ff3ry_j33p likes this.
post #11 of 18 Old 02-22-2016, 09:09 AM
kjeeper10's Avatar
Same setup in the front except both uppers and lowers can be installed with the jeep on the ground. Pinion should be +1 or +2 degrees.
post #12 of 18 Old 02-22-2016, 01:33 PM Thread Starter
CamoCop's Avatar
- remove tires
- mount tires
- drop to ground
so you're saying adjust the lowers to 20.5" or 21.25" (adding the .75")?
- 5.38 Yukon gears
- Lot's of extra's
CamoCop is offline
post #13 of 18 Old 02-22-2016, 02:04 PM
kjeeper10's Avatar
Stock = 19.75
20.5 = + .75
post #14 of 18 Old 02-23-2016, 04:02 PM Thread Starter
CamoCop's Avatar
ok got my axle centered. I went with 21" on the lowers and 18 9/16" on the uppers which is what RK recommended for a 3.5" lift. I found the paperwork with this information in the packing paper. ran out of time so I will put the spring wedges in tomorrow. one thing I noticed now is my rear sway bar links are riding against my axle housing. the top of the sway bar link is actually leaning slightly over the axle housing towards the front of the Jeep. what is everyone doing to solve this issue? will removing the rear sway bar all together make the on road handling significantly worse?
- 5.38 Yukon gears
- Lot's of extra's
CamoCop is offline
post #15 of 18 Old 02-23-2016, 05:21 PM
kjeeper10's Avatar
Move it back 1"
What does your pinion look like?
post #16 of 18 Old 02-23-2016, 07:49 PM Thread Starter
CamoCop's Avatar
pinion angle looks great. right now the axle is almost perfectly centered which is what I wanted. I will just remove my rear sway bar before I move my rear axle back to where it was before I started.
- 5.38 Yukon gears
- Lot's of extra's
CamoCop is offline
post #17 of 18 Old 02-24-2016, 07:33 AM
A JKO DICK
ASSFROW's Avatar
I moved my swaybay back until it was almost touching the muffler. I just marked one side, drilled new holes, tapped them, measured for the other side, rinse, repeat. Metalcloak sells adapters to move it back if you don't want to drill and tap.
ASSFROW is offline
post #18 of 18 Old 02-24-2016, 07:59 AM
kjeeper10's Avatar
Yep ^^^^
