Will I blow a DriveLine? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 15 Old 11-15-2015, 10:59 AM Thread Starter
Okay, so im looking at snagging a 2012+ Rubicon Unlimited within the next month or so, and pretty much not gonna be running on a stock suspension for long. Basically what i was planing on doing is TeraFlex 4" Long Arm kit with a TeraFlex 1.25" Body running on 37's. Now my question is, Is is 100% necessary to upgrade my drive line at that height?
Thanks for any help!
i3ennett is offline
post #2 of 15 Old 11-15-2015, 11:11 AM
front most likely back you probably can get by for a while.
Jadmt is offline
post #3 of 15 Old 11-15-2015, 11:30 AM
jason mac's Avatar
Rear no, front yes. And with a 4" lift there is no need for a body lift if suspension and bump stops are set up correctly.
jason mac is offline
post #4 of 15 Old 11-15-2015, 12:01 PM
Yeah you could easily clear 40s with 4" of lift and flat fenders.
Semper Fi
highoctane is offline
post #5 of 15 Old 11-15-2015, 02:33 PM Thread Starter
Okay thanks for the info, and just to make sure, if i run just the suspension and cancel the Body i would still need to replace my driveline? sorry if thats a stupid question haha
i3ennett is offline
post #6 of 15 Old 11-15-2015, 02:56 PM
Correct. The body lift has nothing to do with the driveline issues you will encounter.
Biginboca is offline
post #7 of 15 Old 11-15-2015, 03:46 PM
kjeeper10's Avatar
I would look at a front DS at least.
kjeeper10 is offline
post #8 of 15 Old 11-15-2015, 09:33 PM Thread Starter
Perfect thanks, ill stick with a 3" suspension and a 1" body then. Thanks for the help!
i3ennett is offline
post #9 of 15 Old 11-15-2015, 09:57 PM
jason mac's Avatar
Why are you doing a body lift?
post #10 of 15 Old 11-16-2015, 12:03 AM Thread Starter
to sqeeze 37's
i3ennett is offline
post #11 of 15 Old 11-16-2015, 04:44 AM
baddkarmaracing's Avatar
This is 37's on 3.5" lift and 3" of bumpstop. I plan to move to a shorter lift sometime in the future just haven't gotten around to it yet
baddkarmaracing is offline
post #12 of 15 Old 11-16-2015, 05:48 AM
JKO Dickhead
Asmmns's Avatar
to sqeeze 37's
You can fit 37's with a 2.5 lift you know ?
__________________
CURE SMA !
Asmmns is offline
post #13 of 15 Old 11-16-2015, 11:40 AM Thread Starter
Okay so no need for a body? Just the 3inch TeraFlex LongArm and I'm good to fit 37's? Cool thanks for the info!
i3ennett is offline
post #14 of 15 Old 11-16-2015, 12:46 PM
jason mac's Avatar
3-4" lift, flat fenders, & 3" bump stops front & rear, and 37's are no problem.
post #15 of 15 Old 11-16-2015, 03:04 PM Thread Starter
Perfect thanks!
i3ennett is offline
