brakes - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 10-13-2015, 06:16 PM Thread Starter
Angry brakes
I was in the bush on single track this past weekend. No harsh driving to speak of. I could hear my brakes squeak every time i backed up. on the way out i could smell the brakes and then the ABS light came on. The brakes were serviced less than 2 months ago. What could be the problem?
Billy G is offline
post #2 of 5 Old 10-13-2015, 07:16 PM
BigTB's Avatar
Were you driving with the parking brake applied?
You say the brakes where serviced recently, what was done?
Check the fluid level and for any signs of a leak.
Year, mileage?
BigTB is offline
post #3 of 5 Old 10-13-2015, 07:22 PM Thread Starter
No the had brake was no on...kept feeling it because it felt like it was on. It's an 08 wrangler jk 2 door. And yes i see a slight wet area around the steel lines under
Billy G is offline
post #4 of 5 Old 10-13-2015, 07:36 PM
BigTB's Avatar
Definitely check the fluid level.
If you banged and crimped a brake line it could be leaking slightly and possibly holding a bit of pressure on the brake it feeds. Just an off the wall idea.
Hard to say for sure what the problem is over the internet.
BigTB is offline
post #5 of 5 Old 10-15-2015, 04:09 AM
Donut707's Avatar
You could have a stuck caliper or pad. if whoever serviced your brakes used a C-clamp to push the piston back inside the caliper they could have damaged it slightly . I have used a C-clamp and done that very thing, a seal started leaking and then the caliper froze (it was on a little Mitsubishi mighty max ) . i had similar symptoms with out the abs light. good luck
Donut707 is offline
