Higher mileage JK, bad idea? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 10-04-2015, 05:17 PM Thread Starter
I've had a couple of JKs in the past (2010 Islander, 2015 Sport) but currently thinking I need another one in my life.
I've found a 2 door 2007 X 6 speed at - what seems to be - a good price (just over $10K) . Clean title, but high-ish miles (140K).
What should I be looking out for? How are these holding up over the years? The automatic trans in my 2010 was junk (needed a rebuild at 35K) but what about the stick? Realistically how good are the engines on these over higher mileages (it's a timing chain rather than belt, I assume?).
Would appreciate any input...
quite98 is offline
post #2 of 7 Old 10-04-2015, 05:37 PM
BeerMonkeY's Avatar
id say it prob doesnt have a long time, my motor blew up at 70k trans at 90k (auto) but my freind works at a dealer where they traded a mail JK in with 298k on it so you never know, even at that price you could put a used motor in if needed and still be good. or you could buy my JK for a little more and not have to worry about it lol
'92 YJ
'13 WK2
BeerMonkeY is offline
post #3 of 7 Old 10-04-2015, 06:48 PM
baddkarmaracing's Avatar
Mine has 135k on on and the the motor was toast when I bought it at 95k about a year ago, as far as I know the trans is original and never been flushed or anything
baddkarmaracing is offline
post #4 of 7 Old 10-05-2015, 08:40 AM
ZacSquatch's Avatar
Got mine with 102K and its running strong. PO used it only as a daily driver/grocery getter in town so it has seen a mild life.
Alaska Oosik's Rugby
ZacSquatch is offline
post #5 of 7 Old 10-05-2015, 10:31 AM
wildchild's Avatar
my '08 with 6 spd has 142K on it. I have had zero issues with motor trans or clutch. oil every 3 thousand religiously though, as well as other normal maint.
wildchild is offline
post #6 of 7 Old 10-05-2015, 04:01 PM
TRAUMAhead's Avatar
110k miles on my 2010 JKUR, auto, daily driver. Engine burns a little more than a qt every 1k miles and the trans shifts a little hard sometimes. Oil changed every 3k.
Only problem I've had with the engine/trans is a broken driver side exhaust manifold which is common. I get a cold start rattle which I'm thinking is the cats, no codes though.
TRAUMAhead is offline
post #7 of 7 Old 10-05-2015, 04:09 PM Thread Starter
Thanks for the input everyone, much appreciated.
quite98 is offline
