Who else has a built in tailgate "slammed shut" sensor - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 09-21-2015, 11:07 PM Thread Starter
misiek's Avatar
I noticed this a while back and today i finally had the wife as a witness so im not going crazy....
When i swing the tailgate closed the passenger side taillight flashes once. It doesn't do it every time and i dont think how hard you close it matters... but it happens enough to notice it
I saw it happen with stock lights and it keeps doing it with led light now. Usally after the jeep was off, like today went to grocery store.. put stuff in back, closed tailgate and flash. .. get home turnoff jeep take all groceries out close tailgate and flash... but i opened it right away and can't duplicate it
Not sure if i should worry about it or is there a quick fix? Gremlin repellent?
misiek is offline
post #2 of 6 Old 09-22-2015, 05:47 AM
my '11 jkuu does this.
I will hazard-a-guess that it has something to do w/ the fact (confusing as heck, btw...) that the Jeep JK/JKUs have independent Right/Left circuits for the tail-lights ( as opposed to the combines taillight circuit on most vehicles) & that shutting the door temporarily ( for a flash) disables the interior dome lights and dash indicator during the slam, enough-so-that the right circuit gets a surge of juice just enough to "flash" the pulse-width-modulated load to the rear right tailight , over the CANBus ....Now,note that I may have the reason for it happening wrong & that deduction has the potential to UTTERLY be the dumbest thing I have ever spewed forth from my pie-hole but , you are not crazy. My stock tails may have done it - i never noticed- but I have run LEDs early from ownership ; i could tell the stock boxes were a vulnerable part and gonna get broken off by me - I ripped those off on trees and the rear right always flashes even with resistors on the LED replacement tails that I run . I replaced the load resistors in the circuit to make sure they weren't the cause.
it flashes like that.
post #3 of 6 Old 09-22-2015, 06:18 AM
ronjenx's Avatar
The tail lights are not pwm. The TIPM sends battery power to the bulbs.
When this happens on the OP's vehicle, he needs to see which filament in the bulb is lighting. (That is, if he's willing to put a stock bulb back in the socket.)
That will provide a place to start investigating.
Here is a picture of the two filaments in the tail light bulb.
ronjenx is offline
post #4 of 6 Old 09-22-2015, 03:56 PM Thread Starter
misiek's Avatar
J33p interesting thought and surprisingly makes sense to me as well....
I just hope that the surge dosent cause bigger problems
Ronjenx i currently have leds... it did it on stock lights and now the whole led taillight flashes...it dim tho its not the brake and it even looks dimmer then the driving setting
misiek is offline
post #5 of 6 Old 09-22-2015, 06:07 PM
did not know that the "tail lights are not pwm" ,ronjenx. I , too, never had this with the stocks now that I really think about it - or maybe I never noticed- but I run LEDs rear and have always had this when I shut the doors or tailgate.
post #6 of 6 Old 09-23-2015, 10:12 AM
piratim's Avatar
I've noticed this as well since I swapped to led bulbs in my tail taillights.. It's on an '09 for what it's worth. I think it does it when I open the tailgate as well. It won't do it for a certain time period after though.
piratim is offline
