2007 JKU Clutch problems - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 09-21-2015, 01:28 PM Thread Starter
I have a 2007 JKU 2wd 6 speed. This morning I jumped in it, started up just fine, pushed the clutch in and tried to put it in gear and it wasn't having it. I killed it, put it in gear then started it and it struggled. I couldn't let off the clutch once I had it in gear nor would it come out of gear. I have been told to check the fluid for it, but where do I find the reservoir for the clutch itself, aside from the brake fluid reservoir? If anyone can help or has an idea, i'm all ears.
HaydenFrederick is offline
post #2 of 4 Old 09-22-2015, 06:21 AM
SGT. Jackalope's Avatar
the clutch shares the brake reservoir, there isn't a separate one for it. Is it just doing it in first? have you tried the other gears?
2007 rubicon unlimited
SGT. Jackalope is offline
post #3 of 4 Old 09-22-2015, 07:49 AM
FuLcRuM's Avatar
Has your throw out bearing been squealing? It may have failed.
My old 07 squealed like a bitch so I replaced the whole clutch and TB. Bearing was shot but the clutch was actually in really good shape. Not a fun job either, highly recommend doing it on a lift if you try it yourself.
Jeepless
FuLcRuM is offline
post #4 of 4 Old 09-22-2015, 02:07 PM
JeepnPokey's Avatar
I bet its your slave cylinder, if you havnt heard any noises like described above, more than likely not its your slave cylinder maybe.
My TB is shot and am putting a new clutch kit and slave cylinder in, sounded like a pissed off dying cat in my transmission....
OIF
JeepnPokey is offline
