Trektop Pro is leaking - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 08-27-2015, 09:38 AM Thread Starter
Anyone with Trektop Pro having problems with rear window leaking? Replaced bottom gasket but still leaking. I have had other problems with top also. Any suggestions?
JeepTex is offline
post #2 of 9 Old 08-27-2015, 01:10 PM
Are you using the Bestop tailgate bar or an oem Mopar tailgate bar? The one that comes with the Trektop is known to leak.
Semper Fi
highoctane is offline
post #3 of 9 Old 08-29-2015, 09:28 PM
Will Scarlet's Avatar
After dealing with Bestop for two different soft tops and the problems with them, my advice would be to just return it. There customer service is lacking.
2011 Sahara Tan Rubicon 6 Speed
TR HD17 Beadlocks, BFGoodrich A/T KO2 34x10.50R17, Teraflex HD Tire Carrier, Clayton 2.5" Overland Plus Lift, and more to come...
Will Scarlet is offline
post #4 of 9 Old 08-30-2015, 12:30 AM
LoneJK's Avatar
Agreed. Have a defective severely ballooning sailcloth top and wrinkled rear window; was told to wait a year and call back. So i did... "Oh it must be your oem hardwear. The top does not look defective, its just part of owning a soft top."
Like hell a top that inflates 3 inches is normal...
Return it. Find a better company
"Gremlin"
LoneJK is offline
post #5 of 9 Old 08-30-2015, 06:49 AM
My Trektop only leaks when it's in the up position, it rains, or i run thru a car wash. The best soltuion i found was to rip out the carpet, pull the plugs, and Monstaline the whole interior. It creates a nice self-bailing cockpit like a boat.
earfixr is offline
post #6 of 9 Old 08-30-2015, 07:40 AM
rlo_jklivin's Avatar
Sounds like ORH ain't as bad as everyone puts Tim out to be. Mine don't even drip.
rlo_jklivin is offline
post #7 of 9 Old 12-02-2016, 09:19 AM
Mine leaks too, in the back window. both sides. tried to replace rubber seal on window bar. did not help. did you discover any fix?
halfdoors is offline
post #8 of 9 Old 12-08-2016, 02:47 AM
If replacing the seals didn't solve the problem, I would contact Bestop.
karlduke is offline
post #9 of 9 Old 12-11-2016, 09:20 AM
Mine is too. Had warrentee fix front doors by lifting door higher just a bit. Tailgate is a disaster. next owner will have to drill a drain hole in the jack compartment. Tried new rubber across bottom of lift glass door,,new sponge strips on tail/g top corners both. Lift glass hatch is nice but not worth the price versus the probs.
