How much grease inside a Rubi sway bar disco? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 08-13-2015, 11:26 AM Thread Starter
Rossi46's Avatar
I ended up getting a Rubicon sway bar double used. The guy who sold it to me had purchased it used and was keeping the motor as a back up for his Rubicon but no longer needs it or the sway bar. He tells me its a crap shoot if it works or not cause he has never tried. I tell him i'm going with the EVO no limits knob and it just so happens the guy who sold it to him gave him that as well as the motor. With the whole contingency is that it might not work but the price is worth it.
So I get the sway bar take off the motor put the EVO knob on and it works perfect! Try it 2nd time then 3rd and then nothing.... Its locked and wont disconnect. I take the whole thing apart to find out it looks like somebody packed grease in there with a spatula. The pics don't even do it justice as I had cleaned half that chit off already. See pictures below... So I clean it up and remove about 95% of the grease best I could put the whole thing back together and its working perfect again. My initial thoughts I'm thinking this one was packed so full of grease it wouldn't allow the fork or collar to shift back and allow it to disconnect.
My question is how much grease does this need to be packed if any at all? From the pictures I have found online (see last two pics) it looks like none.
Pics found online
Rossi46 is offline
post #2 of 6 Old 08-14-2015, 06:37 AM
SGT. Jackalope's Avatar
Mine had got stuck unlocked. I opened it up to find a small bit of rust on the fork and gear and no grease present at all. I cleaned up the rust and put a very light coating of belray water proof grease on it. It's been working great for the past few months.
I'd clean all the grease out of it and just apply a light coating of marine grease on the moving parts to keep it from rusting
2007 rubicon unlimited
SGT. Jackalope is offline
post #3 of 6 Old 08-14-2015, 07:10 AM
ronjenx's Avatar
The one in the "Study" thread was cleaned to show the internal parts.
The grease in your sway bar disconnect, as pictured, is about what it should have in it.
ronjenx is offline
post #4 of 6 Old 08-14-2015, 10:11 AM Thread Starter
Rossi46's Avatar
Thank you to for the advice and thanks again ronjenx for doing that "Study" thread!
I'll replace some of the grease I took out before mounting it up tonight.
Rossi46 is offline
post #5 of 6 Old 08-14-2015, 02:31 PM
While the EVO knob works well, I found you need to lube the thread or corrosion will seize it up. A daub of neverseize helps.
Rodjk is offline
post #6 of 6 Old 08-15-2015, 04:46 PM
07unlimitedx's Avatar
Lots of guys up here in Canuk land are having lots of problems with the Rubi sway locker. In Chrysler's wisdom they use steel and aluminum inside that design. Most have changed them out for something else. Where we wheel, lots of mud and water.
07unlimitedx is offline
