Need help to remove top :(, my jeep is different. - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 08-08-2015, 11:05 AM Thread Starter
Somehow my 2013 sahara Jk 2 door is different than others. How come I have 4 silver bolt like this in the back. It seems they will prevent me from lifting the top.
AND THOSE SILVER BOLT ARE SCREWED FROM THE BOTTOM TO THE TOP, UNLIKING THE TORX 40 BLACK ONES.
NEED HELP DESPERATELY.
mahelun is offline
post #2 of 8 Old 08-08-2015, 11:26 AM
Robnoxious1's Avatar
I think you need bigger pictures. Did you try removing the torx bolts and seeing if it will come off? If it doesnt remove the others. Problem solved.
Robnoxious1 is offline
post #3 of 8 Old 08-08-2015, 11:42 AM Thread Starter
Do you see the silver one beside the black torx? (zoom out to 15% on bowser) It is screwed from bottom to top so it s not removable since no screw drive can get underneath, so i have no idea how to remove it. It has a ring preventing the top from being removed.
mahelun is offline
post #4 of 8 Old 08-08-2015, 11:56 AM
Diesel Jeep's Avatar
Try what Robnoxious said, then if it doesn't come you can freak out! You buddies with jeepmanjim?
Diesel Jeep is offline
post #5 of 8 Old 08-08-2015, 12:00 PM Thread Starter
No, I just joined the community, so it is different from evry jk you have seen right?
mahelun is offline
post #6 of 8 Old 08-08-2015, 12:26 PM
Those are nothing new and are not screws. Those are the tops of the locating pegs that help align the top on the jeep, I have the same thing on mine.
Just take off the torx bolts then remove the top, make sure that all the electrical/washer connections are off first.
Nathan W is offline
post #7 of 8 Old 08-08-2015, 12:46 PM
re:Need help...is different....
google-fu:
"alignment-pin Jeep JK Freedom Top"
as mentioned, your top is not special...you just don't use the googles correctly, dude...
JKs have 6
JKUs have 8
post #8 of 8 Old 08-08-2015, 12:57 PM Thread Starter
AHHH... I was searchin "how to remove silver bolts" / "silver screw in hard top" etc. Guess I should put align-pin in there. Thank you guy so much. That solved my issue cuz i was worried about not being able to take top off.
mahelun is offline
