Help C107C code - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 08-04-2015, 09:57 PM Thread Starter
joebe82's Avatar
Help C107C code
I went wheeling over the weekend. I got
C107C break pedal switch half stuck.
How do I go by releasing the break pedal?
So confused �� �� ��
joebe82 is offline
post #2 of 5 Old 08-04-2015, 11:41 PM
White13JKUR's Avatar
is just the switch stuck or the whole pedal?
the switch is on the upper part of the pedal assembly and the brake pedal arm hits it to make or break contact. there might be two switches.
gently tap the of the switch with the handle of a screw driver. this might release the plunger.
that or maybe hold the brake pedal down with one hand and operate the switch plunger with the other. maybe a shot of wd40 if it's gummed up with something. careful not to pinch your finger.
if you are really gutsy, you might even be able to take the switch apart, clean contacts and put it back together.
White13JKUR is offline
post #3 of 5 Old 08-05-2015, 05:49 AM
maybe got mud or debris or he floor mat up there ?
Likewise, have you sprayed out all the calipers to wash debris/dirt/mud or a possible rock stuck/lodged someplace? Just thinking outside box/objectively for ya....that is one I haven't heard about.....
post #4 of 5 Old 08-05-2015, 09:37 AM Thread Starter
joebe82's Avatar
Thanks. I'll try that when I get home.
joebe82 is offline
post #5 of 5 Old 08-07-2015, 07:23 PM Thread Starter
joebe82's Avatar
So, I changed the clockspring, cause that was one of the errors I was getting as well, and that cleared all my other codes including this one. Phew. 😥 thanks a bunch guys
joebe82 is offline
