The short answer is yes you will get some lift.
The more detailed answer is it really depends. Are the Rubicon springs off of a new or low mileage Rubicon? If so you can expect to gain some lift, but only about an inch maybe an inch and a half. If the springs are off an older Rubi, or one that has high miles or a lot of heavy mods then they could be somewhat worn out and you wont get nearly as much lift from them.
Also if the Rubicon Springs are the 19/60's and your current springs are say 17/58's you wont gain much of anything. The wider the gap in your numbers translates into more of a lift.
Fortis cadere, cedere non potest
Poison Spyder BFH w/ trail stinger, custom rear BFH, crusher flares, rocker knockers, evap skid, hood louver. Rock Krawler 2.5 Max Travel, Teraflex rear tire carrier, River Raider cowl snorkel,Warn VR 10,000 lbs winch, sPod, Rigid 50"SR.
