Jeep JK Regaining "back pressure" - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 08-01-2015, 08:40 PM Thread Starter
So all this talk about back pressure has my mind running..... Lol
So my plan is to throw a flow master 44 but I'm scared I will lose back pressure. I already took my stock exhaust of (looks a lot better off with my PSC rock brawler rear) and I noticed an immense lose in torque. I was backing out of a messed up parking lot and couldn't get out of a small hole at gear (I usually could). So yea if anyone could help me I would great appreciate it! Thanks
Eliasm25 is offline
post #2 of 6 Old 08-02-2015, 01:02 PM
Mtn Derp's Avatar
Define "Took off stock exhaust"
Did you put something else on, or did you whack it back to the downpipes or something?
Wanna make a little money?
Start with a lot of money, buy a Jeep.
Mtn Derp is offline
post #3 of 6 Old 08-02-2015, 02:34 PM Thread Starter
Sorry, removed the muffler and left everything from the rear axle forward as is
Eliasm25 is offline
post #4 of 6 Old 08-02-2015, 03:54 PM
The factory muffler does not put that much back pressure on your system that you would loose torque removing it. or at least not losing an amount you would instantly feel. Most of the restriction in your factory exhaust system is the Cats. To have real gains from the exhaust side of the motor you need to get more in on the intake side of it. The Internal Combustion engine is nothing more then a Big Air pump More that goes into it the more you get out of it,
Tspevacek is offline
post #5 of 6 Old 08-02-2015, 06:07 PM Thread Starter
Thanks for clearifying and I'm running an Airaid intake and have noticed an improvement
Eliasm25 is offline
post #6 of 6 Old 08-03-2015, 07:48 AM
ALASHA's Avatar
No way removing the factory muffler caused that large of a loss in torque if any at all. On my supercharged 3.8, going to catless long tubes only lost 10 hp and somewhere around the same in torque.
ALASHA is offline
