Stuck Socket, Stripped Lugnut - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 07-20-2015, 08:53 AM Thread Starter
sixstring's Avatar
Since I bought my jeep, I have used a 3/4" socket for my lug nuts. I noticed how the stock lug nuts were junk, and for some reason, I refused to use a 19mm.
Problem #1: I was rotating my tires the other day, using a 12pt 3/4" socket. The socket started slipping so I switched to the 19mm, having to tap it on (lightly). The 19mm slipped in both directions and now I can't get the socket out.
Problem #2: If I were to get the socket out, I still have a stripped lug nut that I can't get off and no way to get an Easy-Out down to it.
Does anyone have any suggestions?
sixstring is offline
post #2 of 12 Old 07-20-2015, 08:59 AM
savagemark2's Avatar
You just stripped the cap that goes over top the lugnut
2008 jku rescue green metallic
Warn XD 9000 with Mopar front bumper
rancho 2 inch lift
skyjacker stablizer
a few other after market parts
US WVIANS ARE A LITTLE DIFFERENT THEM THERE CITY SLICKERS
savagemark2 is offline
post #3 of 12 Old 07-20-2015, 09:04 AM Thread Starter
sixstring's Avatar
That's what I was hoping, but I still can't get the socket off.
post #4 of 12 Old 07-20-2015, 09:05 AM
ronjenx's Avatar
If what I see in the center of the socket is the metal cover on the nut, it looks like when the socket slipped, it bunched up the cover material and it's jammed the socket against the wheel.
Have you tried inserting a long extension and wiggling it side-to-side, to loosen it?
If you get the socket out, carefully chisel the cover off the nut. It will reveal a smaller six point nut. A six point socket of the correct size should bring it out.
I haven't had a problem with my stock lugnuts using a six point socket on them.
ronjenx is online now
post #5 of 12 Old 07-20-2015, 10:17 AM Thread Starter
sixstring's Avatar
It's not wedged against the wheel. I've wiggled it, spun it in both directions, put a slide hammer on it, and it's still there.
post #6 of 12 Old 07-20-2015, 10:20 AM
pixeldzn's Avatar
Lesson for the day. Use a 6 point deep well socket for lug nuts.
12 point sockets have their place, and this is not one of them.
- offroad inspired decals for your jeep
2008 Unlimited Rubicon - Silver (Locked and Loaded)
2014 Unlimited Sport - Billet Silver (Mall Crawler)
pixeldzn is offline
post #7 of 12 Old 07-20-2015, 11:27 AM Thread Starter
sixstring's Avatar
I gave up and took it to the local trusted tire shop. The socket is not slipping on the nut, the stud is stripped out at the flange. I have 15" wheels so he can't pull the caliper with the wheel mounted in order to get the axle out to cut the stud off from the back side. Looks like he is going to have to torch everything out from the front. We will see how it goes.
Side Note - I got my tires re-balanced about a month ago and I suspect they put my wheels on with a good dose of impact wrench and didn't bother to check the torque.
post #8 of 12 Old 07-20-2015, 04:00 PM
ronjenx's Avatar
After my new tires were installed, I got home and checked the lug nuts to make sure I could remove them with the regular breaker bar I keep in the jack compartment. They were all too tight, and on at least 6 of them, I had trouble with a 4 foot pipe on the bar. I've had similar experiences at every tire shop I've been to in the past, too, whether or not I asked them to use a proper torque wrench.
post #9 of 12 Old 07-21-2015, 04:33 PM Thread Starter
sixstring's Avatar
Got the jeep back without a boogered up wheel, all new lug nuts, and appropriate torque on all the ones I checked.
post #10 of 12 Old 07-21-2015, 04:49 PM
going forward , as stated , a deep walled , six point socket of appropriate size with an extension suited for impact and a breaker bar or torque wrench and this will be parked away as a lesson learned ...that being use the right tool and trust no one to work on your Jeep but you .
post #11 of 12 Old 07-21-2015, 04:55 PM Thread Starter
sixstring's Avatar
They are all spline drive, so no more wrong socket
post #12 of 12 Old 07-21-2015, 04:57 PM
rock & roll.
