30-40 mph only death Wabble!!!!! - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 07-15-2015, 01:23 PM Thread Starter
wagonguy's Avatar
This thing just started this shake at between 30-40 mph only. No other times or conditions will set it off other than maintaining at that speed. No even bumps in the road. I can power thru it and you never know it's there. Would tire balancing do this?????
wagonguy is offline
post #2 of 8 Old 07-15-2015, 01:39 PM
Robnoxious1's Avatar
Doesnt sound like death wobble sounds like you might have lost a wheel weight or 2.
Robnoxious1 is offline
post #3 of 8 Old 07-15-2015, 02:02 PM
ledzep_06's Avatar
Are we talking "steering wheel shakes but i can keep driving."
Or "holy shit this pig is self destructing and i just shit myself a little."
Generally death wobble is the second one and the only way to stop it is by slowing to a stop or near stoo
ledzep_06 is offline
post #4 of 8 Old 07-15-2015, 02:20 PM
savagemark2's Avatar
have fin figuring it out my jeep is wobble free a the moment. check for mud on the inside of rims also. one day i thought i fucked something up bad when i started dring on the highway i thought my wheel was coming off or something i even pulled over to look what was snapped in two. turned out to be a little mud lol check ur wheel bearings sway bar links look at ur wheel weights if u got spacer check them. make sure everything is torqued properly. make sure there aint a bad band in one of the tires. the list goes on and on
2008 jku rescue green metallic
Warn XD 9000 with Mopar front bumper
rancho 2 inch lift
skyjacker stablizer
a few other after market parts
US WVIANS ARE A LITTLE DIFFERENT THEM THERE CITY SLICKERS
savagemark2 is offline
post #5 of 8 Old 07-15-2015, 02:21 PM
it dont sound like u got death wobble either.
rancho 2 inch lift
skyjacker stablizer
post #6 of 8 Old 07-15-2015, 02:27 PM
Random Dude
+1 on the "probably not death wobble", but:
YES, tire balancing should be corrected / confirmed.
After that, give your ball joints, steering joints, and suspension link joints / bushings a good hard look.
EDIT: unit bearings are a good thing to check, also.
EDIT 2: The track bar is one of those suspension links that needs its joints / bushings scrutinized.
A shimmy from unbalanced tires puts rhythmic loads on all those other things, so tire balance is important.
If any of those other things are worn, they leave room for the shimmy to move shit around more and do more damage, accelerating wear on all the suspension / steering parts.
ExWrench is offline
post #7 of 8 Old 07-15-2015, 02:55 PM
good info never even thought of that. im still a newb though.
rancho 2 inch lift
skyjacker stablizer
post #8 of 8 Old 07-16-2015, 05:26 AM
Canadian-Jku's Avatar
tire balance or rotate them
tire pressures all correct
alignment and everything tight in the suspension front AND BACK
shouldn't take more then a few minutes to check everything go for a drive and narrow it down and resolve it good luck
2012 JKU, shaved 14/SD60hp locked/spooled, 4 link Front 3 link rear, ORis all around, D3 all over, 42" SX2 tires, 20" Trail ready HD double beadlocks, PSC Full hydro
Canadian-Jku is offline
