Anybody make risers for front passenger seat on JK - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 07-05-2015, 12:31 PM Thread Starter
I have been looking for a kit to raise the front passenger seat up a couple of inches so my short passenger could see past the hood. I see them for tj's just not jk's.
Jadmt is offline
post #2 of 11 Old 07-06-2015, 06:28 PM
bigworm36's Avatar
Just get a booster seat
bigworm36 is offline
post #3 of 11 Old 07-06-2015, 06:50 PM
nlgrav182's Avatar
Do you want something to boost the entire seat or a booster seat? I would just use hockey pucks or something like the ghetto bumpstop spacers.
OKAY FUCKMOUTH.
nlgrav182 is offline
post #4 of 11 Old 07-07-2015, 05:19 AM Thread Starter
While I don't plan on being involved in a crash I want my passenger to be safe as possible in case the unforeseen happens so not really wanting to go the ghetto route..
Jadmt is offline
post #5 of 11 Old 07-07-2015, 05:23 AM Thread Starter
We tried the pillow thing but that did not cut it. My wife is 5'2" and shrinking and I did not realize how crappy it was to sit in the pass. seat until I did and even at 5'10" you do not get near the front view as you do in the drivers seat with it raised up. Normal driving no big deal but we play in the rocks and it sure nice to get a better view.
Jadmt is offline
post #6 of 11 Old 07-07-2015, 10:15 AM
svtmaniac's Avatar
What year is your Jeep? My wife is 5' even and she has no issues seeing out of my passenger seat on my 09. Now getting into the Jeep is a whole other issue...
You can live in your Jeep, but you can't off-road your house.
______________________________
2009 JK Rubiclone
6 Speed
svtmaniac is offline
post #7 of 11 Old 07-07-2015, 11:10 AM Thread Starter
2014. sure she can see out. You just get a better view of the front flares etc with the seat up. I run with my seat jacked up all the way at 5'10" to get the best view of the terrain. Heck jack your seat all the way down and compare to what your line of sight is around the fender flares with it jacked up. I see a heck of a lot better at 5'10" with it jacked up vs all the way down.
Jadmt is offline
post #8 of 11 Old 07-13-2015, 11:03 AM
I too was looking for a solution to this I was hoping that maybe a drivers seat could be modified to be placed in passenger side and then both would be adjustable. no such luck.
I agree it would be nice for the passanger to get the same view as the driver for both on road and off.
angryducheman is offline
post #9 of 11 Old 07-13-2015, 11:18 AM
whiteyjfm's Avatar
We have the same problem and I could not find a solution in 3 years.
whiteyjfm is offline
post #10 of 11 Old 07-13-2015, 12:01 PM
Seat elevation
I am the driver. At 5'5" and shrinking, I wanted to be able to see the front fender.
I Gorilla glued four stacks ( of 12 each?) of 1/2" washers to make pucks 3/4" thick, and placed them between the driver's seat mounts and the floor pan, held captive by the bolts. Not the prettiest solution, but functional. I re-used the factory bolts, which I hope still have enough engagement of the threads to be safe. This seemed like a better option than using the longer, non-hardened bolts that I'd gotten from the hardware store.
JJS2 is offline
post #11 of 11 Old 10-24-2015, 10:57 AM
S3AWOLF's Avatar
I was going to say stack washers or try to find some stainless spacer sleeves. If you know someone with a welder once you get the the height you want on the washers have them use c clamps and weld them together to make one solid stack. It will keep them from shifting under the seat mounts.
Also get longer bolts. Even if you can still thread the factory bolts through the washers and make contact you will not have as many threads in as you would normally. Don't risk a weak point. Get longer bolts.
S3AWOLF is offline
