What size? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 05-22-2015, 11:13 PM Thread Starter
What size?
What's the largest dimension tire that would fit under a 10a? I have a 13' rubicon that I put 10a springs paired with Teraflex 1.5 inch front leveling and 3/4 inch puck in the rear. Wondering where my limits are...? Can I fit a 35" x 12.5 x 15 wheel/tire? Would 10 inch be better? How about backspacing, I need to keep the tires under the fenders... What wheel combo will work the best. Thanx
Jstraw is offline
post #2 of 3 Old 05-23-2015, 10:09 AM
sixstring's Avatar
You can fit 35's but since you want to keep the stock fenders, you will need bump stop extensions. There aren't many tire size choices when using a 15" rim so you will probably only find a 35 in a 12.50. The backspacing of the rim determines how far past the fenders the tires will be. Your choices are pretty limited on which 15's you can run on a JK so you may not be able to get the backspacing you need.
sixstring is offline
post #3 of 3 Old 06-07-2015, 05:18 AM Thread Starter
Jstraw is offline
