Unlimited JK clearance vs Cherokee - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 04-05-2010, 08:32 AM Thread Starter
j2k
How much lift/tire would I need on a JK Unlimited to get the same type of clearance for obstacles as a Cherokee on 33's with 4" of lift.
Not many lifted JK's that I've seen around my area for comparison, was hoping you guys had an idea. I just want similar offroad ability without getting high centered on obstacles any more then I might now.
j2k is offline
post #2 of 9 Old 04-05-2010, 08:37 AM
Well.. I know on my 2 1/2 in TF Coil lift I can fit 35in tires.. So right there you are higher then a XJ..
Vote - Bacon for 2012!!!
benmar2000 is offline
post #3 of 9 Old 04-05-2010, 08:39 AM Thread Starter
j2k
Higher in the center of the jeep too? I guess I should figure out what the wheel bases are of the cherokee vs the unlimited.
j2k is offline
post #4 of 9 Old 04-05-2010, 09:48 AM
Yes.. It is higher..
post #5 of 9 Old 04-05-2010, 10:07 AM
Topkicker's Avatar
X2. TF 2.5 will allow for 315/70/r17's (35's).
"Our houses are protected by the good Lord and a gun. You might meet em both if you show up here not welcome, son" - Josh Thompson.
Topkicker is offline
post #6 of 9 Old 04-05-2010, 10:11 AM
JK Inferno's Avatar
XJ's are about 108" and JKU's are 116"
I understand the Jeep thing
JK Inferno is offline
post #7 of 9 Old 04-05-2010, 10:50 AM
The breakover angle on a stock XJ is about 21 degrees, which is about the same as the JK. The XJ should have about 9 inches of underbelly clearence with that breackover angle, the JK, a bit more 9.5 or 10 inches.
The suspension lift should add about 4 inches to the 9, the 33 inch tires about 2 more, so you should have about 15 inches of clearence at the belly.
A JK with a 4 inch lift and 33s would be slightly higher, you could also do a 3 inch lift and 35s. The 35s would give you better clearence at the axles.
Tom
Socal Tom is offline
post #8 of 9 Old 04-05-2010, 10:52 AM
XJs are 101.4 inch wheel base. http://jeephorizons.com/tech/xjstockspecs.html
Tom
post #9 of 9 Old 04-05-2010, 05:36 PM
JK Inferno's Avatar
Tom
I guess the XJ guys I wheel with need to break out the tape measures
