Vibration/shimmy/Shaking problem... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 14 Old 04-05-2010, 08:21 AM Thread Starter
voodoojk's Avatar
I/m about to drive this jeep off a mountain...seriously.
I have a side to side shimmy at a high frequency. When driving i can feel my leg shaking side to side and my driver side mirror is vibrating to the point that i cant see cars when looking in it. Its just a blurr. Its such a high frequency that you dont notice it right away. When i park the jeep and get out im almost sea sick.
Ive put on a new rear drive shaft. Still there. I put on adjustable control arms. Still there. I balanced and rotated tires. Still there. I re-torqued all my suspension. Still there. Replaced the SS with a new fox. Still there.This weekend we installed new ball joints. Mine were destroyed! I thought "yeah gonna ride like new now!" It got worse after the ball joints were replaced. its more defined shimmy now. Only thing i have not tried is removing the front drive shaft that is stock on a 2 dr. I plan to do that as soon as the threat of 2 feet of snow in the next day or so is gone.
My jeep has been riding like a corn wagon for the last couple months. Just a disgusting rough uncontrolled ride. After throwing hundreds of dollars and days of accumulated installs/repairs im still left with a bad riding rig. Funny thing is...it rode perfect for a year after the lift was installed prior to the adjustable control arms and new ball joints.
Any help or ideas...im all ears. My 2007 jeep rides worse then my 1971 bronco did with worn out 26 year old bushings.
2007 Wrangler
Rescue Green
3.5" AEV Lift
37" GoodYear MTR
Pro Comp 7089's
Tom Woods Shafts F&R
OR Fab Tire Carrier
Shaffer Stinger
Bulldog Winch
Buschwacker Flat Flares
Poly Tie Rod
JKS Disco
voodoojk is offline
post #2 of 14 Old 04-05-2010, 08:50 AM
gt3073b's Avatar
Check the unit bearings and make sure the axle shafts aren't bent. Try jacking up one wheel at a time and spinning it to see if it runs true.
Bryan.
2007 JK Rubicon Unlimited Rescue Green 6 Speed
Mods Shrockworks Rails & Bumpers, Currie Lift, Tom Woods 1350 driveshafts, 35" Toyo M/Ts on ProComp 7028s
In Progress
To Do
gt3073b is offline
post #3 of 14 Old 04-05-2010, 09:39 AM Thread Starter
voodoojk's Avatar
seems to be okay...we had the bearings off and the axles out doing my ball joints saturday. Everything looked ok.
2007 Wrangler
Rescue Green
3.5" AEV Lift
37" GoodYear MTR
Pro Comp 7089's
OR Fab Tire Carrier
Shaffer Stinger
Bulldog Winch
Poly Tie Rod
JKS Disco
voodoojk is offline
post #4 of 14 Old 04-05-2010, 09:54 AM
bodybrdng's Avatar
I would highly recommend taking it to a lift friendly shop. Sounds like the death wobble to me
bodybrdng is offline
post #5 of 14 Old 04-05-2010, 10:22 AM
JIMBOX's Avatar
I'm just guessing--but
It sounds like your adjustable control arms aren't in SYNC (diff. lengths)and your two sides (jeep) are trying to catch up with each other
Alignment shop that works on JEEPS
Good luck
JIMBO
Man, you gotta have style
"YELLOW JEEP No. 683"
JIMBOX is offline
post #6 of 14 Old 04-05-2010, 10:24 AM Thread Starter
voodoojk's Avatar
huh? strange answer lol. I work at a dealership with a full shop. I dont need to take it some where..i just need to figure out what it is. Its not death wobble. Nothing to do with it.
2007 Wrangler
Rescue Green
3.5" AEV Lift
37" GoodYear MTR
Pro Comp 7089's
OR Fab Tire Carrier
Shaffer Stinger
Bulldog Winch
Poly Tie Rod
JKS Disco
voodoojk is offline
post #7 of 14 Old 04-05-2010, 11:17 AM
bent axle tube ?
im searching now for off set ball joints i have the same issue and was told that my front axle was bent at the knuckle off like a 1/2 degree good luck
igivup is offline
post #8 of 14 Old 04-05-2010, 06:20 PM
Exclamation
I don't no if I can help you but once I had a problem like your and the garage were I bot my mags and tires they told me that they have to glue the tires on to the mags because I could't keep the tires balances until they glue them to the mag I hope it help !!!!!!
JK STORM is offline
post #9 of 14 Old 04-05-2010, 06:28 PM
levellinebrad's Avatar
did you do track bars with your lift? If not then perhaps your driveshafts being skewed to the side could be causing this. Just a guess on my part. good luck.
levellinebrad is offline
post #10 of 14 Old 04-05-2010, 07:22 PM
NE Wrangling's Avatar
A Couple of questions:
Do you feel the shimmy in the steering wheel first or does the shaking begin elsewhere before you feel it in the Steering wheel.
Was it all arms that were replaced?
Measure the front axle and rear axle to make sure they are centered under the jeep.
Re tourque all bolts in the suspension. My guess is one has not been fully tourqued if it's not one of the above.
I'd like to know what you Caster is set at.
You didn't mention having your tires balanced in the original post? I'm assuming they have been done since you've started the troubleshooting. A wheel weight can fall off pretty easy if you use the ones for the outter edge. Is it possible one of the tires has a issue with a radial belt internally?
jk-forum, jk forum, jkforum, jeep jk wrangler, jk-forum.com, jeepforum, jk-board.com, wayoflife, 2007 jk, 2008 jk, 2009 jk, 2010 jk, jk, jk wrangler
Never argue with an idiot, they will bring you down to their level then beat you with experience.[/SIZE][/B]
NE Wrangling is offline
post #11 of 14 Old 04-06-2010, 07:17 AM
zwvirtual's Avatar
I was going to do a write up about my experience with the "hippy-hippy-shakes".
From day 1 of buying new tires I couldn't figure out what was going on. Always at 52-54 mph I would get a slight shimmy. I've taken the tires to get them rebalanced about 3-4 times, had an alignment done and finally a road force balance.....nothing. I even took it to a "lift friendly shop and they couldn't figure it out. All the shops said my tires were starting to cup. Then I read about a shop in Boulder, CO (not far from where I live) that does tire shaving, which will remove the cupping. I took it there and when they took the wheels off first thing he pointed out where these:
He said these spacers tend to cause a lot of problems for jeep owners. Take one or two off, then put your wheels back on and it's going to set your wheel at the wrong angle. He did a minor shave job on my tires, took all of the spacers off (he said he doesn't know why Chrysler puts them on in the first place) and I've been running great since!
Looking back at the time I put my 1.5" spacers on which was about 2 days before I got my new tires I remember taking a few of these washer-spacers off.
So if you're having a shimmy problem rip those damn things off and see if it makes a difference. If you need any further tire help check out the Tire Source in Boulder. Excellent shop!
2009 Wrangler X Sport, Silver
BFG KM2's
2.5" Rough Country suspension lift
Rough Country Disconnects
Rubicon Rock Rails
zwvirtual is offline
post #12 of 14 Old 04-06-2010, 09:47 AM Thread Starter
voodoojk's Avatar
thanks for all the advice. I have front lower and rear up control arms. Tires are fresh balanced. NOt sure what my caster is but front control arms are set at TF specs for my jeep. The problem existed prior to control arm install. Didnt change after install. Tires and wheels are the same as the day i put the lift on. Tires are wearing PERFECTLY. problally the most perfect wear pattern i have ever had on a tire. Im stumpped. The jeep rode like a dream with just the TF 3" and moster track bar and everything set up. So i shouldnt need to install control arms and stuff...because it rode and drove perfectly. Guess stuff wears out..i wonder if my TF shocks are shot? I already replaced 3 of them for leaking.
2007 Wrangler
Rescue Green
3.5" AEV Lift
37" GoodYear MTR
Pro Comp 7089's
OR Fab Tire Carrier
Shaffer Stinger
Bulldog Winch
Poly Tie Rod
JKS Disco
voodoojk is offline
post #13 of 14 Old 04-06-2010, 11:25 AM
babiehughie's Avatar
This could cause it. One old worn out shock and three newer ones trying to compensate. Good Luck.
Originally Posted by STUPIDFACE View Post
I have 2 legs, but 3 knees....right knee.....left knee.....wee knee....
Jack of all Trades, Master of Some
babiehughie is offline
post #14 of 14 Old 04-06-2010, 06:03 PM
terrahawk's Avatar
YouTube - High Heal Fall :LiveLeak/NBC News
terrahawk is offline
