Axle U-joint question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 03-27-2010, 09:45 AM Thread Starter
tkob1060's Avatar
ok I had my Jeep in shop yesterday for ball joint replacement, so the mechanic calls and tells me my axle u-joint on passenger side is bad, says it will only bend/flex in one direction. Does that make any sense? Does not seem possible to me that the flexing one way would lock up.
tkob1060 is offline
post #2 of 6 Old 03-27-2010, 11:22 AM
Broncojohn's Avatar
If its out it may apear that it wont move but frozen up due to wear it will move under the weight of the Jeep. It should move by hand even if it's stiff, Your mechanic saved you some coin. If he put it back in and it went your new balljoints may have suffered.
Broncojohn is offline
post #3 of 6 Old 03-27-2010, 11:37 AM Thread Starter
tkob1060's Avatar
I had him put it back in for now. I didnt want to spend any money on the stock axles I am just going to order the RCV's on Monday. No 4wd till I get the new axles in. I was going to order them in a few weeks anyhow. He couldnt find a replacement u-joint other then from the dealer he said anyhow. I know there is one right? I'll fix them once I upgrade so I have good spares for when someone else breaks theirs
tkob1060 is offline
post #4 of 6 Old 03-27-2010, 11:43 AM
Broncojohn's Avatar
Keep an eye on it. With the new unit bearings the axle is engaged all the time. If the U-joint goes it will eat up the area 4wd or not. It would be better if he took the u-joint out, left the stub shaft in, and plugged the axle tube.
post #5 of 6 Old 03-27-2010, 05:46 PM Thread Starter
tkob1060's Avatar
thanks John for the info, I'll be driving it as little as possible till I get the new axles in, hopefully next weekend. I guess its pretty good I didnt drive 1100 miles and go wheeling this weekend then
tkob1060 is offline
post #6 of 6 Old 03-27-2010, 05:52 PM
Broncojohn's Avatar
That wouldn't have been fun, I've been running around with only a stub shaft since KOH. I have RCV's sitting in the garage waiting for a home, just need some time.
