Door Hinge Bushing Fit - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 04-18-2015, 09:52 AM Thread Starter
mecheng10's Avatar
For those of you that have replaced the bushings on your door hinges, what kind of fit have you observed on the replacement bushings of various types (plastic, metal, etc.) and from different suppliers? What did you purchase and who from? Were they too loose, too tight?
mecheng10 is offline
post #2 of 10 Old 04-20-2015, 09:38 PM
Are you referring to the Delrin bushings? Mine fit very snug. I very gently tapped them into the hinges with a plastic mallet. They don't move at all and my doors go on and off like butter. So far, after a year, they're holding up well. As far as where I purchased them, the website doesn't appear to be in business any more, but I paid $30 for mine (2 Door). Check out this website: http://www.justjeepgear.com/TMR-Cust...ers_p_942.html
2013 COMMANDO GREEN
6-Speed, A/C, 3.73's
Support the 2nd Amendment - It's your right!
MOLON LABE
Scott2373 is offline
post #3 of 10 Old 04-21-2015, 03:49 PM
Rancho Suspension's Avatar
Yep I am running TMR's too.
I used a long 9mm socket to pop out the old ones.
Rancho Suspension is offline
post #4 of 10 Old 04-21-2015, 06:48 PM
http://www.magnitude-engineering.com...&product_id=55
I just installed these. They fit perfectly. Doors open and close like new now and they come right out!
08 JKU 6.0 LC8 6L80 Atlas 2 39" KM3's on Trilogy race beadlocks, prorock 44,rcv's arb front. rock jock 60 rear 40spline shafts,arb 5.13's and a bunch of other stuff
89yjon is offline
post #5 of 10 Old 04-21-2015, 06:51 PM
Just saw that you are actually the one that sells those... Lol
89yjon is offline
post #6 of 10 Old 04-22-2015, 06:42 AM
Not sure if I should ask this here or in a new thread...
What are people using to replace the rusting out stock pins? How hard is it to remove/replace the pins?
My bushings are already delaminating and are shot. the pins are rusting (thanks New York!). Might as well do both when I pull the hinges to powdercoat them.
Edit:
What are the differences between the TMR and Magnatude bushings? Why is one more expensive?
Grimscale is offline
post #7 of 10 Old 04-22-2015, 08:45 AM
See below for more info.
What are people using to replace the rusting out stock pins? This Delrin bushing replaces the stock. How hard is it to remove/replace the pins? Not too hard soak them with a penetrating oil, like PB Blaster. Use the long 9mm socket to knock them out.
Edit:
post #8 of 10 Old 04-22-2015, 10:11 AM
kjeeper10's Avatar
Bought TMR's Ty
kjeeper10 is offline
post #9 of 10 Old 04-22-2015, 10:14 AM
kjeeper10's Avatar
Oops lol
post #10 of 10 Old 04-24-2015, 07:49 PM
Edit:
I'm a Rochester native as well, so I used Never Seize on the hinges from day one of owning the Jeep. As far as cost of the bushings, that's all it is. Delrin is Delrin, so follow the link I posted above for TMR and they're only $30. Same as Rancho, I used a 9mm deep socket to remove the old bushings. I used a good heavy maul and with two whacks they were out. Just be sure to protect the door in case you slip with the BFH!
2013 COMMANDO GREEN
MOLON LABE
