TJ springs on a JK? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 04-17-2015, 12:54 PM Thread Starter
TJ springs on a JK?
I am about to pull the trigger on a lift for teh JK (2008 unlimited), however just came across some posts on other forums about using JK springs (stock) to lift a TJ..... interesting, similar fit and a possible free lift if you have the JK parts laying around for your TJ
I have some new TJ Rubicon Express lift springs at home, so am curious about trying them up and see if they woudl actually work. Anyone has any info before I go in that path? I believe my TJ lift springs are either 5" or 7" new from a long arm kit from my TJ. I ended up never using the springs and they are just sitting on the shelf...
quoting an old post here "Also I know that poly performance / synergy suspension lists there TJ/JK front lift springs with the same part number for a 3" lift. ...PPM-8063-20." and directly from Poly's site: http://www.polyperformance.com/Syner...ngs?multi=2039
Thanks!
Gui
geberhard is offline
post #2 of 6 Old 04-17-2015, 12:59 PM
Ronson's Avatar
Fronts work rear don't. It will be less than advertised lift IIRC.
Ronson is offline
post #3 of 6 Old 04-17-2015, 12:59 PM Thread Starter
So yep answering my own question looks like the TJ springs (at least fronts) shoudl work on a JK, and will be close to 1 less inch of lift on a JK compared to a TJ - I am not considering spring rating etc, just part numbers:
8063-20 Jeep TJ/LJ 2.0" Front Lift Springs
8063-20 2-Door Jeep JK 3.0" Front Lift Springs
post #4 of 6 Old 04-17-2015, 10:14 PM
jksrep's Avatar
Yeah, that's all right. Honestly I wouldn't go there, your springs will be more compressed than they were designed, leaving you with a squishy ride and a lack of options when you add bumpers, armor, ect.
Pete from JKS Manufacturing
jksrep is offline
post #5 of 6 Old 04-18-2015, 08:17 AM
Coil rates would be all out of whack as the JK is much heavier then the TJ.
I would expect them to be super soft and compress too easy over rough surfaces.
post #6 of 6 Old 05-04-2015, 08:00 PM Thread Starter
guys thanks for the info, yep biting the bullet and going with a full kit. thanks!
