Tips for removing a transfer case? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 04-06-2015, 06:54 AM Thread Starter
SofaKing's Avatar
I need to remove and open my transfer case. It doesn't look very complicated but are there any tricks or hints that will make it easier?
2009 Silver Unlimited Rubicon -- Not really stock, anymore.
SofaKing is offline
post #2 of 6 Old 04-06-2015, 09:59 AM
Mason's Avatar
Whenever I've taken them out a set of stubby wrenches has helped for the top bolts, and I unbolt the trans crossmember and support it with a floor jack and let it droop down a bit to get my arm around to the top bolts. Other than that it is normally straight forward.
Mason is offline
post #3 of 6 Old 04-06-2015, 11:14 AM
Jeepineer
JKred07's Avatar
I've never bothered with the cross member, but thats just me.
Stubby 9/16" is mandatory. I also have a ratcheding 9/16" box end wrench and a long socket extension with swivle head or u-joint adapter to get at the nuts by the linkage plate.
Its an easy removal though.
-Mike
JKred07 is offline
post #4 of 6 Old 04-06-2015, 12:52 PM
Mason's Avatar
If you have smaller arms you may not need to. I'm a fairly solid guy so I needed the extra clearance just to fit my arm around it on both my truck and Matti's jeep. But I can't stress the stubby wrenches enough, if you have ratcheting stubbys even better.
Mason is offline
post #5 of 6 Old 04-06-2015, 02:39 PM
Ringer's Avatar
I built this to reach over the case.
Name:  ImageUploadedByAG Free1428352771.714399.jpg
Ringer is offline
post #6 of 6 Old 04-10-2015, 11:43 PM
ockgator's Avatar
Don't drop it on your foot
Proud to be deplorable
ockgator is offline
