Problems fixed in newer Models of JK? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 03-22-2010, 08:42 AM Thread Starter
ksjeep's Avatar
I have an 07. I am wondering if the 09/10 models have fixed some of the annoying little problems...
1. The leaking hose for the rear window washer on the hard top ( where it plugs in)
2. The plastic keepers that hold the rear window bar on the soft top. They continually pop off... usually the drivers side.
3. ETC., ETC. I'm sure someone will bring up something I forgot.
ksjeep is offline
post #2 of 13 Old 03-22-2010, 08:50 AM
Born2run's Avatar
Hey KS- Don't want to hi-jack your post, but what size wheels and tires you running on your rig?
I was looking at your avatar picture and trying to find a combination that will work under my stock fenders. Are you running spacers?
To answer your questions nothing like that has happened on my 08 JK.
Born2run is offline
post #3 of 13 Old 03-22-2010, 09:09 AM
GOWREVER's Avatar
I'm guessing 35's, cause if they were any bigger they wouldn't stuff, least that's how it looks. I'm thinkin the wheels are "Pro Comp Rock Krawlers" I had a set just like those, in fact I've got some for sale. 16x8
"Dude, did you see that Green Jeep out in the parking lot?"
"Yeah, its' mine..."
GOWREVER is offline
post #4 of 13 Old 03-22-2010, 09:32 AM
Originally Posted by ksjeep View Post
1. The leaking hose for the rear window washer on the hard top ( where it plugs in).
Still a prollem. I have an 09 and it does this to me from time to time. If you haven't used the rear washer in a while, that stuff STANKS
Dancin Dan is offline
post #5 of 13 Old 03-22-2010, 12:18 PM
I have a 08 and swap tops or go topless a few times a year and none of the issues that you described or really any issues close to what you have described. I have yet to read anyone post up the effectivness of the new softop with cables or the new added latch at the front loop to see if they are anymore effective, bit my 08 has been leakless untill I open the doors and it pours in from the gutters, good luck and sorry you are having issues.
rob4607 is offline
post #6 of 13 Old 03-22-2010, 02:51 PM
LSUjeepguy's Avatar
Your #2 keeper problem: mine were not giving me any problems, but the service dept said there was a recall or reb on them and replaced them for me with a newer ones.
No other problems I can think of.. I've got an 08 with 24k miles...
____________________
Quote: Originally Posted by aaronkushner BBrish.....im not the a Mets fan like you....who the retard now? lmao
LSUjeepguy is offline
post #7 of 13 Old 03-22-2010, 03:42 PM
mrsig's Avatar
I have not had any of them problems!! So far!
CEO of Black Sheep 4x4s
mrsig is offline
post #8 of 13 Old 03-22-2010, 03:44 PM
SONIC's Avatar
1) Havent put the hard top on in a year
2) ORH softtop
3) all other problems essentially the result of a) being stupid b)someone else being stupid
-Doc Holiday
SONIC is offline
post #9 of 13 Old 03-22-2010, 06:58 PM
I have an 09 Sahara UL, hardtop leaks at the rear window seal on the tail gate. Always wet at the sub woofer mount. Soft top leaks on the passenger front (just behind the windshield). I've noticed a small leak on the engine thermostat housing at the gasket. I'm not sure if the 07/08 models had the same issue's or not?
JK_hammer_47 is offline
post #10 of 13 Old 03-23-2010, 07:44 AM
Jason @ Warrior's Avatar
Strange, I never had any of these problems on either of our 07's, our 08, or our current 09...
The only problems we ever had were
1. Crappy underpowered motor
2. Drive by wire
3. Overly computer controlled vehicle
4. ESP
5. Oh and I bent a rear axle shaft before even touching a trail at Moab last year in the Rubi.
Jason @ Warrior is offline
post #11 of 13 Old 03-23-2010, 09:09 AM
Steveqvs's Avatar
Lets not forget the ever popular gas gushing on hands and feet when using the autofills at the gas stations!
Steveqvs is offline
post #12 of 13 Old 03-24-2010, 04:19 PM
Krunchytaco's Avatar
Heres a few you forgot to add,
How about the Windshield wipers sticking.
And the drivers door strike clunking when you hit a bump.
And the center console being four inches to short.
And the Leaking water pump with 28k on the motor.
And theres the ESP thing
And the occasional ignition not starting the engine thing.
And the shitty plastic that scratches when you touch it!
And the no paint behind the door hinges.
Some complaints I have with Jeep...
Krunchytaco is offline
post #13 of 13 Old 03-25-2010, 06:51 AM Thread Starter
ksjeep's Avatar
I knew guys wouldn't let down! I forgot a bunch of them...
My wheels are ProComp 17", tires are 33" Procomp, with a Rubicon Express 2.5" lift.
I need to update my Avatar.... now with my new tube fenders and additional lift... same tires... I NEED 37" tires!
So... Santa... can you maybe send me some 37" tires... I've been real good
ksjeep is offline
