Axle bender - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 03-30-2015, 09:28 PM Thread Starter
joebe82's Avatar
Axle bender
Fixed the freaken slave. The plastic piece that looks like a cap inside the tranny, makes contact with the fork, well that was broken. Replaced it, and immediately got pressure back. Woot woot.
Whole new problem now. I got a little crazy at the lake, I bent the rear axle.
What can I use to replace? Stock? Is there something better?
joebe82 is offline
post #2 of 11 Old 03-30-2015, 09:41 PM
there is much better options out there, price it out. i just made a pros and cons list with prices for a customer and to upgrade both axles to core 44s from g2 wasnt much less than putting one tons under it. the big question is what are you plans with the jeep? 35s and down or 37 and up? trail riding or crawling?
rockcrawler1981 is offline
post #3 of 11 Old 03-30-2015, 11:01 PM Thread Starter
joebe82's Avatar
Don't plan to crawl it. More trail riding and dune fun. I went from stock gears to 4.88. It's my daily ride. Should my gearing matter? Once I make my choice, and I have that part of my jeep open, what else should i replace? The housing looks straight.
joebe82 is offline
post #4 of 11 Old 03-30-2015, 11:14 PM
what did you bend? as for dunes are you jumping it? 6in or10ft dont matter.
post #5 of 11 Old 03-31-2015, 12:16 AM Thread Starter
joebe82's Avatar
The rear axle on the driver side. The wheel doesn't spin straight. I don't intent to jump, but I get a little bit of air.
joebe82 is offline
post #6 of 11 Old 03-31-2015, 12:37 AM
Mason's Avatar
Did you bend the shaft, or the whole housing?
Mason is offline
post #7 of 11 Old 03-31-2015, 06:24 AM Thread Starter
joebe82's Avatar
The shaft. The housing looks straight.
joebe82 is offline
post #8 of 11 Old 03-31-2015, 06:44 AM
kjeeper10's Avatar
Sure it's not just the flange ? Common issue !!!
kjeeper10 is offline
post #9 of 11 Old 03-31-2015, 07:57 AM
TCdawg's Avatar
Sounds like you bent the flange. Pretty common even with chromo rear shafts.
Replace with a brand that warranty's bent flanges...one I know for sure is Ten Factory. There is another I think but the company escapes me.
You want a big boy fix....Full Float rear, but that comes with a price.
TC
TCdawg is offline
post #10 of 11 Old 03-31-2015, 03:03 PM Thread Starter
joebe82's Avatar
It was late last night. Soon as i get home ill tear it apart and report back.
I'll look at the flange, hopefully that's it. Easy fix and be ready for Pismo Dunes this weekend. If axle im busting a mission to get it ready.
joebe82 is offline
post #11 of 11 Old 04-01-2015, 05:09 PM Thread Starter
joebe82's Avatar
I fix my jeep guys. It was the axle that was bent. Bent the shaft and the spline. I went with stock for now. Will look into upgrading i the near future. Thanks guys.
joebe82 is offline
